Derek Toering Posted April 22, 2010 Posted April 22, 2010 Is there a way to rearrange the list of items that come up when I do a right click? My problem is that when items are selected, then I right mouse click, the move and copy commands are on top of each other. Often when I want to copy something it is very easy to move it instead. If I can rearrange this list I could alleviate this problem. Thanks. Quote
ReMark Posted April 22, 2010 Posted April 22, 2010 Have you checked to see if right-click menu is listed in the CUI editor as being available for customization? Why not consider assigning Copy and Move to your mouse buttons instead? Quote
MARKY Posted April 22, 2010 Posted April 22, 2010 i had that problem with the erase command. if you right click on an empty portion of a tool bar space, not actually on the toolbar, and click on cui or customize it'll bring up a window. expand all the carrots so you can see all commands. in thhe top portion of the window you'll see all the menus, toolbars etc. i think it's under shortcut menus and then edit menu. right click on one of the commands you have a problem with a choose insert seperator. or just drag the command up or down. you can also drag new commands up from the bottom window to your edit menu. Quote
