Hi,
I need to get the coordinates of the video limits of a drawing (not the drawing extent). I have tried getting "LIMMIN" and "LIMMAX" variable, but is not the result that I need.
I need these points because I need to know the limits of the wmf exported. Now I can only read them -by-hand- with the "status" command
Thanks
Thanks for you reply, but I haven't found Vpmax/Vpmin variables. I'm using ACad2008.
I have tried, but VSMin / VSMax are not the values Im looking for. Any other guess?
Now I have understood how to calculate the Y coordinates of the LL/UR corners of the screen view (=VIEWCTRy +(-) VIEWSIZE /2) . But how to get the Height/Width ratio of the screen to calculate the X coordinates using VSMin / VSMax? Sorry, but I'm not so smart with view and viewport.
I tried this, it works sometimes, not always. What I've found is that using Vsmax/Vsmin doesn't always give the ratio of the screen size
(defun test ()
 (setq vmax (getvar "vsmax")
   vmin (getvar "vsmin")
   vctr (getvar "viewctr")
   vhgt (getvar "viewsize");view height
   vrat (/ (abs(- (car vmin)(car vmax))) (abs (- (cadr vmin)(cadr vmax)))); view width/height ratio
   vwid (* vrat vhgt);view width
   vll (list (- (car vctr) (/ vwid 2)) (- (cadr vctr) (/ vhgt 2))); Lower left coordinates
   vur (list (+ (car vctr) (/ vwid 2))(+ (cadr vctr) (/ vhgt 2))); Upper right coordinates
I've had that same problem in the past.
I use a bit different approach:
[b][color=BLACK]([/color][/b]defun c:scrsize [b][color=FUCHSIA]([/color][/b]/ tdef c x y ll ur[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]command [color=#2f4f4f]"_.VIEW"[/color] [color=#2f4f4f]"_Save"[/color] [color=#2f4f4f]"TMP"[/color][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]setq tdef [b][color=NAVY]([/color][/b]tblsearch [color=#2f4f4f]"VIEW"[/color] [color=#2f4f4f]"TMP"[/color][b][color=NAVY])[/color][/b]
          c [b][color=NAVY]([/color][/b]cdr [b][color=MAROON]([/color][/b]assoc 10 tdef[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
          x [b][color=NAVY]([/color][/b]cdr [b][color=MAROON]([/color][/b]assoc 41 tdef[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
          y [b][color=NAVY]([/color][/b]cdr [b][color=MAROON]([/color][/b]assoc 40 tdef[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
         ll [b][color=NAVY]([/color][/b]list [b][color=MAROON]([/color][/b]- [b][color=GREEN]([/color][/b]car  c[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]* x 0.5[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
                  [b][color=MAROON]([/color][/b]- [b][color=GREEN]([/color][/b]cadr c[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]* y 0.5[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
         ur [b][color=NAVY]([/color][/b]list [b][color=MAROON]([/color][/b]+ [b][color=GREEN]([/color][/b]car  c[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]* x 0.5[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
                  [b][color=MAROON]([/color][/b]+ [b][color=GREEN]([/color][/b]cadr c[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]* y 0.5[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]list ll ur[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
Crude, but then acad can be crude as well. -David
Nice David... as crude as you may think it is, at least it gives accurate/consistent results. I would have never thought of saving a View and using tblsearch.
Sometimes crude works for me! Forcing ACAD to do the work is also my favorite things to do.
Another way to calculate the x:
(* (getvar "VIEWSIZE) (/ (car (getvar "SCCRENSIZE"))
                        (cadr (getvar "SCREESIZE"))))
This one is a little better because it should be a bit smaller than the actual size. -David
from David Bethel's example above, this should work
(setq vctr (getvar "viewctr")
   vrat (/ (car (getvar "screensize"))(cadr (getvar "screensize")));view width/height ratio
I feel a bit sheepish not knowing of the sysvar Screensize; never had an occasion to use it. Ya learn something new every day...
Wow, thanks for your answers.
The last method leave a little error on the x coordinate.
My purpose is to draw localized point on the WMF exported file and I need to be 100% precise. So I would like to read the view data. The problem is that I use VB with Autocad 2008 and I don't know how to get the "current view" object, or how to save a new view with the current dimensions.
Dim v As Common.AcadView
v = acadCurrentDoc.Views.Add("TMP")
MsgBox(v.Width & ", " & v.Height)
With this code v doesn't contain the W&H of the current view.
Can you give me more help?
Thanks
