missing pop menu (file, Edit, Tools, ect)
I am using AutoCAD Architecture 2010. I am missing my File, Edit, View, Insert, Format, Tools tool bar. I tried to type in menubar but it keeps telling me "No menus are defined". Please help.
have you installed it recently? repaired it? try the command MENULOAD
I reinstalled it and that didnt help. When I use MENULOAD, what menu's do I need to load to use the architecture features like build? I loaded ACAD menu and then lost the walls, windows and stuff like that.
Do you have another computer with Arch CAD that you can check? I only run vanilla AutoCAD so I can't say what you should have in that list. But I would guess that the Arch-menufile is somewhere close to your ACAD-menufiile, but that is just a guess.
I personally have not upgraded past 09, but I do know that the ribbon became standard in the 2010 release. There is a download from Autodesk somewhere that includes the classic ui elements IE the pull down menus. They should also be found within the upper left corner while clicking on the big A.
