comcu Posted August 26, 2008 Posted August 26, 2008 Hi, Can anyone direct me to a good example of drawing multilines using vba? I looked in the help file but doesnt seem to be a lot of info on it? Cheers, Col Quote
rocheey Posted August 26, 2008 Posted August 26, 2008 You seed your points as XYZ sets, so the number of points for the 'main' part of the line will be an array of sets of 3: the points on your main line will be indexes 0,1,2 for the first point, indexes 3,4,5 for the second point, indexes 6,7,8 for the third point. etc, etc. The Justification is the side to offset by. acTop & acBottom are which "side" to offset your "main" line by: acZero basically offsets both lines from your imaginary line running down the middle of your points. MLineScale controls the offset amount. The sample code provided in the help, is not much help. Take the sample code, erase all the points except those from index 0-8, and make them the following values: 0=0. 1=0. 2=0. 3=0. 4=-10. 5=0. 6=10. 7=-10. 8=0 This will basically make an "L" shape, unlike the overlapping crap that the sample source gives you. Then play with the Justification and MLinScale properties; you should get the hang of it then. Quote
fixo Posted August 26, 2008 Posted August 26, 2008 Hi, Col Not sure about what you mean but hope it will helps, just pick points on screen Public Sub DrawMLineDynamicaly() ' partially borrowed from Tony Tanzillo's 'Getpoint' function Dim pickPt As Variant Dim mlCoords() As Double Dim i As Integer Dim oMline As AcadMLine i = 0 On Error Resume Next pickPt = ThisDrawing.Utility.GetPoint(, vbCr & "First point: ") If Err = 0 Then ReDim mlCoords(2) mlCoords(i) = pickPt(0): mlCoords(i + 1) = pickPt(1): mlCoords(i + 2) = 0# Do Until Err.Number <> 0 i = i + 3 pickPt = ThisDrawing.Utility.GetPoint(pickPt, vbCr & "Pick next point or press Enter to stop: ") ReDim Preserve mlCoords(UBound(mlCoords) + 3) mlCoords(i) = pickPt(0): mlCoords(i + 1) = pickPt(1): mlCoords(i + 2) = 0# If oMline Is Nothing Then Set oMline = ThisDrawing.ModelSpace.AddMLine(mlCoords) oMline.Update Else oMline.Coordinates = mlCoords oMline.Update End If Loop End If End Sub ~'J'~ Quote
comcu Posted August 26, 2008 Author Posted August 26, 2008 Fixo, Thank you for that. What I am trying to create is a version of the code you posted but to allow the user to type in size,s width, height and qty of bays and to end product to be curtain walling screen. Thank you for thehelp. Cheers, col Quote
comcu Posted August 26, 2008 Author Posted August 26, 2008 Rocheey, Thank you for the explanation. You didn’t mention mlinestyle? I see from help that it is read only? I tried MyObjMLine.stylename = “MLineStyleName” And it returned an error. Does this mean it can not be changed with vba and you have to do it manually? Cheers, Col Quote
fixo Posted August 27, 2008 Posted August 27, 2008 Rocheey,Thank you for the explanation. You didn’t mention mlinestyle? I see from help that it is read only? I tried MyObjMLine.stylename = “MLineStyleName” And it returned an error. Does this mean it can not be changed with vba and you have to do it manually? Cheers, Col Col, please, take a look at the Help always: From Help StyleName For the MLine object, this property is read-only To set desired MlineStyle use: ThisDrawing.SetVariable "CMLSTYLE", "MyStyleName" '<--style name the same things with scale and justification: ThisDrawing.SetVariable "CMLSCALE", 10.0 <--scale ThisDrawing.SetVariable "CMLJUST", 1 '<--justification to middle After that you can draw multiline with desired parameters ~'J'~ Quote
fixo Posted August 27, 2008 Posted August 27, 2008 Fixo, Thank you for that. What I am trying to create is a version of the code you posted but to allow the user to type in size,s width, height and qty of bays and to end product to be curtain walling screen. Thank you for thehelp. Cheers, col Col, sorry, I don't understand what you mean Please, upload here the small picture or the sample drawing to enlight me with it ~'J'~ Quote
comcu Posted August 27, 2008 Author Posted August 27, 2008 Thank you for the set variable, it worked fine. I doo look at help but some times find it hard to get what i am looking for. Thank you for the help. I will post a sample drawing/ jpeg later today. I would appreciate any pointers. i think i can use the code you posted but jsut have the points calculated from input added by the user. will post the jpeg later. thank you for the help. cheers, col Quote
comcu Posted August 27, 2008 Author Posted August 27, 2008 Fixo, jpeg attached. it is a very simple example, the amount of columns/ rows could 10 or 100, for eg. Im sure i can use you example, i just need to work out how to accept input from the command line and then work out the calculation required. cheers, col Quote
fixo Posted August 27, 2008 Posted August 27, 2008 Here is an example what you looking for I don't like to use command line for entering values, so I used InputBox instead: Sub DrawFrameTest() Dim strMStyle As String Dim structWid As Double Dim frameWid As Double Dim structHgt As Double Dim frameHgt As Double Dim beamWid As Double Dim hnum As Integer Dim vnum As Integer Dim varpt As Variant Dim hstep As Double Dim vstep As Double Dim pts(5) As Double Dim movept(2) As Double Dim oMLine As AcadMLine Dim cMline As AcadMLine Dim cnt As Integer strMStyle = "STANDARD" structWid = CDbl(InputBox("Structural Opening Width:", "Structural Width", "7733.0")) frameWid = CDbl(InputBox("Frame Width:", "Frame Width", "7712.0")) structHgt = CDbl(InputBox("Structural Opening Height:", "Structural Height", "2986.0")) frameHgt = CDbl(InputBox("Frame Height:", "Frame Height", "2966.0")) beamWid = CDbl(InputBox("Beam Width:", "Beam Width", "50.0")) ThisDrawing.SetVariable "CMLJUST", 1 ThisDrawing.SetVariable "CMLSTYLE", strMStyle hnum = CInt(InputBox("Number Of Horizontal Beams:", "Horizontal Beams", "4")) vnum = CInt(InputBox("Number Of Vertical Beams:", "Vertical Beams", "4")) varpt = ThisDrawing.Utility.GetPoint(, vbCr & "Pick lower left point of construction:") ThisDrawing.Regen acActiveViewport 'calculations hstep = (frameWid - (beamWid * vnum)) / (vnum - 1) vstep = (frameHgt - (beamWid * hnum)) / (hnum - 1) pts(0) = varpt(0) - beamWid: pts(1) = varpt(1) + beamWid / 2: pts(2) = 0# pts(3) = pts(0) + frameWid: pts(4) = pts(1): pts(5) = 0# 'horizontal beams Set oMLine = ThisDrawing.ModelSpace.AddMLine(pts) oMLine.MLineScale = beamWid oMLine.Update Do While cnt < hnum - 1 Set cMline = oMLine.Copy cMline.MLineScale = beamWid cMline.Update movept(0) = varpt(0) movept(1) = varpt(1) + (cnt + 1) * (vstep + beamWid) movept(2) = 0# cMline.Move varpt, movept cnt = cnt + 1 Loop 'vertical beams cnt = 0 pts(0) = varpt(0) - beamWid / 2: pts(1) = varpt(1): pts(2) = 0# pts(3) = pts(0): pts(4) = pts(1) + frameHgt: pts(5) = 0# Set oMLine = ThisDrawing.ModelSpace.AddMLine(pts) oMLine.MLineScale = beamWid oMLine.Update hstep = (frameWid - (beamWid * vnum)) / (vnum - 1) vstep = (frameHgt - (beamWid * hnum)) / (hnum - 1) Do While cnt < vnum - 1 Set cMline = oMLine.Copy cMline.MLineScale = beamWid cMline.Update movept(0) = varpt(0) + (cnt + 1) * (hstep + beamWid) movept(1) = varpt(1) movept(2) = 0# cMline.Move varpt, movept cnt = cnt + 1 Loop End Sub ~'J'~ Quote
comcu Posted August 27, 2008 Author Posted August 27, 2008 Fixo, thank you. it worked really well. I will try to develop it further. Many thanks, Col Quote
