clsnyder Posted April 27, 2010 Posted April 27, 2010 Hello everyone, Im trying to directly select a block by name so that I can move it from where ever it may be, to where I want it. Moving a block isnt whats giving me an issue as im useing the ThisDrawing.SendCommand "move 0,0". However I cannot seem to get vba to select the block so I can move it. I cant use a window to select it because sometimes the block is over top of other geomatry or text and I dont want to move that. And the block isnt always in the same spot so I cant select it by insertion point. Hopefully this made sense. Thank you in advance cal- Quote
fixo Posted April 27, 2010 Posted April 27, 2010 Hello everyone, Im trying to directly select a block by name so that I can move it from where ever it may be, to where I want it. Moving a block isnt whats giving me an issue as im useing the ThisDrawing.SendCommand "move 0,0". However I cannot seem to get vba to select the block so I can move it. I cant use a window to select it because sometimes the block is over top of other geomatry or text and I dont want to move that. And the block isnt always in the same spot so I cant select it by insertion point. Hopefully this made sense. Thank you in advance cal- Try this one 'publish by Design, Minkwitz 'Date: Mar/11/02 'Re: Assign selected text to block attribute Option Explicit Declare Function GetAsyncKeyState Lib "user32" (ByVal vKey As Long) As Integer Function GetEnt() As AcadEntity Dim Ent As AcadEntity Dim Pt As Variant Set Ent = Nothing On Error Resume Next Do ThisDrawing.Utility.getentity Ent, Pt, "Pick an Object :" If Err Then If GetAsyncKeyState(&H1B) Then Err.Clear Exit Do ElseIf ThisDrawing.GetVariable("errno") = "7" Or _ ThisDrawing.GetVariable("errno") = "52" Then Err.Clear End If End If If Not Ent Is Nothing Then Set GetEnt = Ent Exit Do End If Loop End Function Sub Try() Dim oBlkRef As AcadBlockReference Dim oEnt As AcadEntity Dim insPt As Variant Dim toPt As Variant Set oEnt = GetEnt() If Not TypeOf oEnt Is AcadBlockReference Then MsgBox "Selected is not a block reference." Else Set oBlkRef = oEnt insPt = oBlkRef.InsertionPoint With ThisDrawing.Utility toPt = .GetPoint(insPt, vbCr & "Specify second point:") oEnt.Move insPt, toPt End With End If End Sub ~'J'~ Quote
BIGAL Posted April 28, 2010 Posted April 28, 2010 What about something like Dim SS As AcadSelectionSet Dim objENT As AcadEntity Dim Count, Cntr As Integer Dim Newpitname As String Dim pitname As String Dim FilterDXFCode(0) As Integer Dim FilterDXFVal(0) As Variant FilterDXFCode(0) = 0 FilterDXFVal(0) = "INSERT" 'FilterDXFCode(1) = 2 'FilterDXFVal(1) = "SCHEDTEXT" BLOCK_NAME = "SCHEDTEXT" Set SS = ThisDrawing.SelectionSets.Add("pit1sel") SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal For Cntr = 0 To SS.Count - 1 If SS.Item(Cntr).Name = BLOCK_NAME Then attribs = SS.Item(Cntr).GetAttributes If attribs(0).TextString = pitname Then do move now The code will find all blocks with block_name but the second filter checks the attribute pitname so only one block moves. Quote
clsnyder Posted April 28, 2010 Author Posted April 28, 2010 attribs = SS.Item(Cntr).GetAttributes Thanks guys this has gotten me a bit closer. I guess I should have added a bit more information. See my problem is I have these old drawings, and the blocks on these drawings have been updated with new attributes. It is the function of my program to insert a new version of the block, then sync the old version with the new version, then delete the "new" version, which only leaves the one. However when i do this, for some reason Autocad always moves the original block to another location. Which leads me back to having to move each block. What type of veriable is attribs? it gives me a variable not defined error. Sorry AutoCad and I dont really get along. But thank you both for your help its been very useful. Quote
dbroada Posted April 28, 2010 Posted April 28, 2010 my guess would be that the new block and the existing block do not have the same insertion point as I have done this many times without a problem. Quote
clsnyder Posted April 28, 2010 Author Posted April 28, 2010 yeah they do have different insertion points. Which is part of the reason why I am updating these old blocks. that way in the future they all are the same and have the same insertion points. Quote
dbroada Posted April 28, 2010 Posted April 28, 2010 and that is why all your blocks are moving. When you sync the existing blocks to the new one the old insertion point stay where it is but the geometry will alter around it. I once wrote a routine to shift all the blocks by x,y for somebody but they had all sorts of scales and rotations too so it wasn't very useful. Are all your blocks moving by the same amount or will you have to fiddle with it after you run your routine? Quote
clsnyder Posted April 28, 2010 Author Posted April 28, 2010 picture this I have five years worth of drawings that have been made by X number of people. Each person made the drawing however they wanted but they all "look" the same. The blocks are named the same, and for the most part they have 90% of the same attributes in them. So along I come and I have to bring all these old drawings and blocks into alignment. So, i drop in a new block, I sync it and then remove the block I just dropped in. Now the original block is up to date but totally in the wrong place. Because of how the drawings were all done, each block needs to be selected, then moved. If I could use a mouse I could just click the block, type in the move command, and BAM its done. But I cant use a mouse because I have to automate the process. So yeah, thats my drama. Why you couldnt just type in a "select Block X" command is beyond me. Quote
clsnyder Posted April 28, 2010 Author Posted April 28, 2010 you can - use QSELECT QSELECT isnt an option because it opens a window. the object was to automate everything to that the program does everything for you. Quote
dbroada Posted April 28, 2010 Posted April 28, 2010 in that case BigAl's selection set is probably the easiest way to progress. If you aren't doing any thing with attributes you don't need the two lines dealing with attribs. I'm guessing he posted a bit of code he already had sitting around. my similar code will create a selection set of all the blocks in my drawing named STL* gpCode(0) = 0 'item gpCode(1) = 2 '? groupCode = gpCode dataValue(0) = "INSERT" 'item type dataValue(1) = "STL*" '? dataCode = dataValue Set mySelSet = ThisDrawing.SelectionSets.Add("Blocks") mySelSet.Select acSelectionSetAll, , , groupCode, dataCode For Each myItem In mySelSet Quote
