Is there a quick/easy way of comparing system variables with a 'problem machine' to that of a machine that works fine?
As we all know Autocad does some odd things sometimes - and it's usually a system variable setting change. The problem is trying to locate which one. In the system variable editor, it is possible to save all system variables with their settings, and print them out, which about 10 A4 Sheets. These can be compared to a machine that has no problems, which long and tedious.
Does anyone know of a program or better method of finding differences in system variables between two machines?
thanks
SF
i would export the system variables from the two machines in the way that you are doing, and then copy and paste them both into one excel file, and compare them in there. i've done this in the past and was surprised at how many variables were different; and thus gave me ideas of what to put into a company acad.lsp file
Express Tools has one, type Vars2Scr.
thanks Alan - but all that does is just print out a list of current system variable settings and it does not give any comparsion
Come on man, use a little imagination.:wink: I think Notepad++ has an option to compare contents of two text files.
thanks but I think I will stick with Lloyd Beachy's Sysvar lisp - its far easier to use once it's modified
Modify away. I just wanted you to be aware of Vars2Scr. :)
After going cross eyed changing it:?, here is the updated lisp (for acad 2010) hope someone else finds it useful.
SysVar.lsp
Why put yourself through all that? either use Notepad++, or use Vars2Scr, and run each file through something like this:
(defun c:FileCompare (/ _read f1 f2 out l1 l2 x y o )
 (defun _read ( file / o n lst )
   (cond (  (setq o (open file "r"))
            (while (setq n (read-line o))
              (setq lst (cons n lst))) (close o)))
   (reverse lst))
 (if (and (setq f1  (getfiled "Select File 1"      "" "txt" 16))
          (setq f2  (getfiled "Select File 2"      "" "txt" 16))
          (setq out (getfiled "Select Output File" "" "txt"  1)))
     (setq l1 (_read f1) l2 (_read f2) o (open out "w"))
     (while (and (setq x (car l1) y (car l2)))
       (or (eq x y) (write-line (strcat x "\t\t\t" y) o))
       (setq l1 (cdr l1) l2 (cdr l2)))
     (close o) (startapp "notepad" out)))
 (princ))
LoL You're more popular. Maybe he'll listen to you.:wink:
   (reverse lst))
 (princ))
I use
C:\Program Files\Autodesk\ACADM 2011\Support\acadinfo.lsp
and UltraCompare ... but any file comparer will work well
