joining multiple DWG files into one file
Hi
I have 4 large DWG files which are 4 quadrants of an inner city map and i want to see all 4 in one file so i can isolate a section in the middle which includes parts of all four different files. I have tried the merge function with no joy.
Sorry i am a total beginner, using a full version of AutoCAD 2010
Open one drawing file and insert the other three quadrants. Use the Insert command.
I have tried the merge function...
What is the "merge function"?
cats... skinning.... just sayin'.
Merge isn't a valid command in 2009 does it exist in 2010?
Both methods of inserting (or copy basepoint & paste) or xref are good ways to do what you want.
Just tried it in 2011 and it doesnt work either
In 2010 there is an attach button under the insert tab, which by it's own description should do exactly what i want it to do, but it surly doesn't.
Have you tried any of the above mentioned suggestions?
Sorry, yes i have
and i have worked out a solution that fits, by just opening all files and copying from one file and 'pasting to original co-ordinates' in another, they fit together like a dream. Sorry i am a total beginner.
My next question is how to extract an exact 1024 by 1024 meter area from my now large map.
Thanks for all the replies guys
You might try taking a look at EXTRIM command (Express Tools - command line only) or a lisp routine called CookieCutter. There should be a link to it somewhere around here as I've mentioned it in the past. Just search on the words and you should find it. There are probably a couple of other similar lisp routines "out there" that can achieve the same results.
excellent stuff. It took me a bit of messing about, with extrim command first then cokkiecutter2, but CC2 appears to have done exactly what needs to be done.
sound advise
thank you
