how do I change the default border etc for idws?
i have a copy of the border and title block i want to use, but how do i make it the default one so when i start a new idw, its already there?
Open your template file and add it to the Drawing Resources folder in the browser. Save and close the template file.
File>New and select the template.
You can also select your template to be the new default when creating a new drawing. The Files tab on the Options menu has a section for Template settings where you can browse out to your template in the "Default Template File Name for QNEW". This way, your drawing template will open by default when you launch AutoCAD or click on the New Drawing button on the toolbar. Not sure if that's what you're after, but it might save you some time if you're using that template exclusively.
Huh? Are you lost? This is not the AutoCAD forum. :lol:
yeah, i just realized that i did save the template as the default in standard... but i've been opening new metric idw lately, it didn't click til now that i have to make it the metric default as well
hey jd, is that you in your avatar? because honestly, it's a little creepy
edit: i realized i wrote the post poorly the first time
I'm completely lost. :-\ And it's not even Friday yet.
As Popeye would say, I am what I am.
Always with the right answer JD. You are a real Prof.. keep up with the good work.
Congratulation.
