nootie Posted May 2, 2010 Posted May 2, 2010 Hello, I have 50 layouts with 2 viewports. For each viewport, i have to freeze some layers. So I have to select the left viewport from the layout and freeze or unfreeze some layers, then I select the right viewport and also freeze or unfreeze some other layers. I have allready find some code on the internet but I still have two problems: 1. I can't select two different viewports. It is always the same viewport who acitvates. Sub SetupFullSizeTab() Dim objVPLeft As AcadPViewport Dim objVPRight As AcadPViewport Dim objEnt As AcadEntity Dim objLayout As AcadLayout Dim bTest As Boolean Dim xL As Double Dim xR As Double ThisDrawing.SetVariable "CTAB", "FULL SIZE" For Each objEnt In ThisDrawing.ActiveLayout.Block 'this test skips the first object in the layout which is always _ the PS Vport of the layout itself If bTest = True Then If TypeOf objEnt Is AcadPViewport Then If objVPLeft Is Nothing Then Set objVPLeft = objEnt Else Set objVPRight = objEnt xL = objVPLeft.Center(0) xR = objVPRight.Center(0) If xL > xR Then Set objVPRight = objVPLeft Set objVPLeft = objEnt Exit For Else Exit For End If End If End If Else bTest = True End If Next ''do whatever with the 2 viewports now objVPLeft.DisplayLocked = False objVPLeft.Display True ThisDrawing.MSpace = True ThisDrawing.ActivePViewport = objVPLeft ThisDrawing.Application.ZoomExtents objVPLeft.StandardScale = acVpCustomScale objVPLeft.CustomScale = 0.25 / 12# objVPLeft.DisplayLocked = True objVPRight.DisplayLocked = False ThisDrawing.ActivePViewport = objVPRight ThisDrawing.Application.ZoomExtents objVPRight.StandardScale = acVpCustomScale objVPRight.CustomScale = 0.25 / 12# objVPRight.DisplayLocked = True ThisDrawing.MSpace = False End Sub 2. I work with polygonal viewports and the code for unfreezing the layers always works with new viewports. But each time the code add a new viewport, it's never a polygonal viewports. Doesn't there exist a code for unfreezing the layers without removing the viewport. Sub testVplayerOn() Dim strLayer As String Dim objPviewport As AcadPViewport Dim Pt1 As Variant Dim strPrompt As String On Error GoTo err_selectVPobjectsToFreeze ' set an undo mark in the drawing ThisDrawing.StartUndoMark If ThisDrawing.ActiveSpace = acModelSpace Then MsgBox "This program only works with PaperSpace Viewports" & vbCr & _ "Please go to PaperSpace", vbCritical Exit Sub End If ' let's get into Paper Space ThisDrawing.MSpace = False ' Select a viewport ThisDrawing.Utility.GetEntity objPviewport, Pt1, "Select ViewPort:" strPrompt = "Enter Layer Name to thaw in Veiw Port: " ' Ask the user for a layer to thaw in the Paperspace View port strLayer = ThisDrawing.Utility.GetString(True, strPrompt) ' run the main program that does the grunt of the work ' yhea for vpLayer on! VpLayerOn strLayer, objPviewport ' Place an end to the undo mark ThisDrawing.EndUndoMark ' exit this sub Exit Sub ' error handling err_selectVPobjectsToFreeze: MsgBox Err.Description, vbInformation Err.Clear ThisDrawing.EndUndoMark End Sub ' Next the VpLayerOn! Sub VpLayerOn(strLayer As String, objPviewport As AcadPViewport) Dim XdataType As Variant Dim XdataValue As Variant Dim newXdataType As Variant Dim newXdataValue As Variant Dim I As Integer Dim counter As Integer Dim Pt1 As Variant Dim varCenter As Variant Dim dblWidth As Double Dim dblHeight As Double Dim objViewPortNew As AcadPViewport ' Get the Xdata from the Viewport objPviewport.GetXData "ACAD", XdataType, XdataValue For I = LBound(XdataType) To UBound(XdataType) ' Look for frozen Layers in this viewport If XdataType(I) = 1003 Then ' Set the counter AFTER the position of the Layer frozen layer(s) counter = I + 1 ' Match the layer we are looking for and exit the sub -- ' bingo we have the frozen layer location! If UCase(XdataValue(I)) = UCase(strLayer) Then Exit For End If Next ' Layer not found in this Mview If counter = 0 Then Exit Sub ' pull Width Height and Center from selected veiwport dblWidth = objPviewport.Width dblHeight = objPviewport.Height varCenter = objPviewport.Center ' set the Xdata for the layer that is beeing frozen newXdataType = XdataType newXdataValue = XdataValue ' work throught the remaining array... For I = counter To UBound(XdataType) ReDim Preserve newXdataType(I - 1) ReDim Preserve newXdataValue(I - 1) newXdataType(I - 1) = XdataType(I) newXdataValue(I - 1) = XdataValue(I) Next 'objViewPortNew.SetXData XdataType, XdataValue Set objViewPortNew = ThisDrawing.PaperSpace.AddPViewport(varCenter, dblWidth, dblHeight) ' Apply xdata to new Pviewport objViewPortNew.SetXData newXdataType, newXdataValue ' Put the new viewPort on the same layer as the original viewport objViewportNew.Layer = objPviewport.Layer ' Refresh viewport!! ThisDrawing.MSpace = False objViewPortNew.Display (False) objViewPortNew.Display (True) ThisDrawing.Utility.Prompt ("Done!" & vbCr) ' Delete Old viewport objP[font=Courier New]viewport.Delete[/font] [font=Courier New] [color=navy]End Sub [/color][/font] thx Quote
nootie Posted May 6, 2010 Author Posted May 6, 2010 Does nobody has a solution for these problems Quote
audeser Posted May 5, 2021 Posted May 5, 2021 (edited) I know this thread is 11 years old, and probably is useless for you right now, but your code was really illustrative for me; so, to get info under the same thread, I will continue the post, if it could help somebody in the future. For the first issue, following code solves the matter, first activates one, the activates the other one: Private Sub SetupFullSizeTab() ' select two different viewports... one after the other Dim ocadDrw As AutoCAD.AcadDocument Dim ocadVPortLft As AutoCAD.AcadPViewport Dim ocadVPortRgt As AutoCAD.AcadPViewport Dim ocadEntity As AutoCAD.AcadEntity Dim ocadLayout As AutoCAD.AcadLayout Dim Coordinates As Variant Dim bTest As Boolean Dim xL As Double Dim xR As Double Set ocadDrw = ThisDrawing With ocadDrw ' Add a Layout, activate, and enter PViewPort ModelSpace '.Layouts.Add "SomeName" '.ActiveLayout = .Layouts("SomeName") 'or: .SetVariable "CTAB", "FULL_SIZE" ' activates the tab with that name... For Each ocadEntity In ocadDrw.ActiveLayout.Block ' test skips the first object in the layout (which is always the PaperSpace Vport of the layout itself) If bTest = True Then If TypeOf ocadEntity Is AutoCAD.AcadLWPolyline Then ' when the viewport is not rectangular, there is a LwPolyLine embebded ' To change coordinates: Coordinates = ocadEntity.Coordinates Coordinates(0) = 150 ocadEntity.Coordinates = Coordinates ocadEntity.Update End If If TypeOf ocadEntity Is AutoCAD.AcadPViewport Then If ocadVPortLft Is Nothing Then Set ocadVPortLft = ocadEntity Else Set ocadVPortRgt = ocadEntity If ocadVPortLft.Center(0) > ocadVPortRgt.Center(0) Then Set ocadVPortRgt = ocadVPortLft Set ocadVPortLft = ocadEntity End If 'Exit For End If 'Else ' Debug.Print ocadEntity.ObjectName End If Else bTest = True End If Next ' do whatever with the 2 viewports now .MSpace = True .ActivePViewport = ocadVPortLft With ocadVPortLft .DisplayLocked = False .Display True ocadDrw.Application.ZoomExtents .StandardScale = acVpCustomScale .CustomScale = 0.25 / 12# .DisplayLocked = True End With ' Change to the other viewport .ActivePViewport = ocadVPortRgt .MSpace = True With ocadVPortRgt .DisplayLocked = False ocadDrw.Application.ZoomExtents .StandardScale = acVpCustomScale .CustomScale = 0.25 / 12# .DisplayLocked = True End With .MSpace = False End With End Sub The second one, should be solved with VPLAYER command Sub sLayers_PViewport_VPlayer() ' more info in the following reference: ' www.contractcaddgroup.com/articles/vport.htm ' Freeze / Thaw to unfreeze... ' NewFrz to freeze on new viewports... ' Transparency ' reMoveOverrides ' vpVisDflt ' Color ' LWeight ' LType Dim ocadDrw As AutoCAD.AcadDocument Dim pviewportObj As AutoCAD.AcadPViewport Set ocadDrw = ThisDrawing With ocadDrw '.Layers.Add ("Apple") '.Layers.Add ("Orange") .ActiveLayer = .Layers("Orange") .ActiveSpace = acPaperSpace .ActivePViewport.Display (True) .MSpace = True ' Go freeze some layers... (works even if layers do not exists) .SendCommand "vplayer freeze 0,Apple,Orange" & vbCr & vbCr & vbCr ' Go unfreeze some layers... (works even if layers do not exists) .SendCommand "vplayer Thaw 0,Apple" & vbCr & vbCr & vbCr '.ActivePViewport.DisplayLocked = True .MSpace = False End With End Sub Edited May 6, 2021 by CADTutor Moved code to code block (BBCode is not supported) Quote
mhupp Posted May 6, 2021 Posted May 6, 2021 (edited) On 5/6/2010 at 1:56 PM, nootie said: Does nobody has a solution for these problems Might want to post in the .NET, ObjectARX & VBA forums This is for AutoLISP, Visual LISP & DCL --edit-- lol didn't see the 11 year old post Edited May 6, 2021 by mhupp Quote
