shame on you JD :) sketch fillets and an under defined sketch:)
Hey, I had to leave something for the OP. As far as the fillets - I put those in the sketch so that I could have an extra tight bend, if I hadn't put them in sketch is there a way in SolidWorks to have multiple bend radii in a single feature? I think any reference you find that I recommend not using sketch fillets I include the qualifier "usually".
  • Replies 21
  • shift1313
    8
  • JD Mather
    7
  • Ubatoid
    7
Posted Images
If you leave the fillet out of the sketch you can only apply a single radii. Unless you did the miter in several different sketches which would be cumbersome.
