How do you go about this?
It used to be a) Object, b) Property, c) Match Property
Can't find out how to do this in the AutoCAD Mechanical 2011
Help?
Type in "ma" & enter
select source objects :
select destination objects :
Isn't there a Match Properties icon on the Ribbon you can select?
First, thank you both for responding.
The "MA" typed in does work so that is the good news.
I have looked all over for a MATCH PROPERTIES icon and can find nothing. If anyone comes across it please let me know.
Again, THANKS!
Look in your AutoCAD Help file for the MATCHPROP command and it should open to the Quick Reference tab. Under the heading Access Methods it will tell you all the ways to invoke the command. If it is on the Ribbon somewhere it will be noted.
I can tell you that in my 2010 AutoCAD help it says that MatchProp should be on the Home-ribbon, on the Properties panel - but I have stared at that panel more than a few times and don't see it.
I resorted to the CUI and added the button myself.
Again, THANKS!
You are most welcome.
I just gave you an immediate solution.
Ahead just follow the instructions from our "QM", u ll never be in a loss.
In plain 2010 the MATCHPROP icon can be found on the Home tab > Clipboard panel.
i like the matchprop command, makes life easier...
Add it to the Quick Access Toolbar (QAT), upper left, down arrow, check Match Properties
Does it say that in your Help-file?
