cadamrao Posted May 3, 2010 Posted May 3, 2010 Hi I’m using civil 3D 2010.I created corridor 1, corridor 2 and also intersection; please help, how to join (corridor 1, corridor 2 and intersection) a single section. Plz guide me steps how to do this Thanks Amr Quote
BIGAL Posted May 4, 2010 Posted May 4, 2010 We dont use corridors but another addon but I would expect proceedure is the same. using corridor 1 update your surface model to reflect changes save as surface 2. have corridor two resample new surface and then update surface to reflect changes save as surface 3 using intersection now update surface 3 and save as surface 4 Updating 1 surface at a time and resampling can give a better final model versus just pasting all corridors in one go. Save each surface as you can delete at any time and it makes it easier if a surface combine doesn't work right. Hope this helps Quote
sinc Posted May 4, 2010 Posted May 4, 2010 Is there a particular reason you used three Corridors? The usual practice is to use one Corridor, unless you have a very complex site with flyover ramps, etc., and you have to split up your design into multiple Corridors. What do you mean by "join to a single section"? Do you simply want to combine the surfaces? Or are you talking about something else? Combining the surfaces should be as easy as creating a new surface, and pasting your Corridor surfaces into it. If you're talking about cross-sections and stuff like that, then things might get more involved. Quote
