Recently after importing a file a cad from a civil engineer, our base files have jumped to 2.58 mb as a standard even when every object has been deleted. The only layer left after purging is the "0" layer and a zillion layer filters which don't seem to have any layer associated to them. This file has now been imported into most of our base sheets and the files all start at 2.58 mb Any advise as to how to remove them and reduce the file size?
You might try the -purge command and select the Regapps option. A regular purge won't take these out.
Purge, -Purge and Audit will not remove layer filters. Try the lisp routine below, posted by CarlB on another forum, a long, long time ago.
(princ "\nType LFD to start")
(defun C:LFD ()
(vl-Load-Com)
(vl-Catch-All-Apply
'(lambda ()
(vla-Remove (vla-GetExtensionDictionary
(vla-Get-Layers
(vla-Get-ActiveDocument
(vlax-Get-Acad-Object))))
"ACAD_LAYERFILTERS")))
(princ "\nAll layer filters have been deleted.")
(princ))
Run the routine and then Purge your drawing.
FYI: I generally clean any files I get from outside sources before using them as Xrefs. I save out a copy of the original and then I Purge & Audit the files and then I Wblock them out to a new file. This gives me a clean, unbloated, file to work with. Since I started doing this, I haven't had any problems with my drawings. No sluggish performance and no crashes.
Thank You all for the help. The LISP routine and a final purge saved the day and reduced the typical 3 mb file to 180kb... Yahooo
