profcad Posted May 3, 2010 Posted May 3, 2010 How do you add material to a family when the family is made of a single 3D model imported from AutoCAD? Quote
rvpas Posted May 30, 2010 Posted May 30, 2010 Hi John, If you use differentes layers in your drawing You can change in revit by override Imported Object style 1st - Settings menu / Object styles 2nd - choose Imported Objects tab (you will see the layers from your autocad drawing) 3rd - click material field to change your material by layer 4th - and ok Have a nice day Pascal Quote
