I'd like to add the option to make multiple copies of a particular layout in paperspace as part of my right-click menu. The only way right now I make copies takes too many clicks. Thanks.
You mean copies of tabs? you can right-click on an active tab and have it copy everything onto a newly created tab.
Is that what you're referring to? You want to do it multiple times?
Have you tried holding down the shift button and highlighting multiple tabs, so it does it several copies at once? Then select those too, and then you're doing 4 at a time, etc..
If you want it even faster than that for some reason, I'd suggest using a script for it, but I'm thinking that's probably fast enough?
*UPDATE* clocked myself at 16 copies in 20 seconds without really trying.
2010 > Hold Ctrl down, click and drag the tab, done.
Even better, thanks alot!
