That helps a lot, Lee! Thanks!
The move section is part of a much larger lisp that I am trying to construct as a learning exercise. For some reason I keep trying to plug in number or calculations to avoid so much user input. That doesn't work for me.
The routine will eventually split a box into three sections, move one end to the new measurement, and move the center section half of that distance- I hope...
Thanks again, very helpful!
doug
  • Replies 25
  • ready2goriding
    14
  • Lee Mac
    6
  • alanjt
    5
  • fixo
    1
Posted Images
Its Alan's way of making testing for null user input - it works as the AND statement will stop evaluating expressions as soon as it reaches an expression that returns nil. But I don't like that construct in a whole program IMO.
A very simple code using Move - obviously this code is redundant, with no advantage over the move command, but it serves as an example.
(defun c:test ( / ss p1 p2 )
 (if (and (setq ss (ssget "_:L"))
          (setq p1 (getpoint "\nSpecify Base Point: "))
          (setq p2 (getpoint "\nSpecify Next Point: " p1)))
   (command "_.move" ss "" p1 p2))
 (princ))
Just for posterity, what would be the advantage/reasoning of this over just a simple and statement?
In my humble opinion I feel that the use of the IF statement is better programming practice - I would think it would be more consistent with other languages.
For the given situation, it just seemed superfluous. Either works with exact same results and many use both methods, I know I have/do. It boils down to a matter of opinion.
I just wish that I knew enough to have an opinion! :(
