Hi,
I have a Problem now..
I have a BLOCK, contains object & Blocks, that Blocks also contains objects and blocks and so on..
ex.
BLOCK
|—Objects
|—Block
|—Objects
|—Block
|—Objects
|—Block
now my Question is " How can change property of the source BLOCK and change effects on all members chain "
Can it Possible
have any command or Lisp code for this?
Thanks & Best Regards8)
—Sam
It sounds like you have a fairly complicated "nested" block.
Is the "source" block the one at the deepest level?
I don't know about "nested object"
have any solution of my problem...
Regards,
I was trying to educate you about the correct terminology. Blocks within blocks are considered to be "nested".
Do I have a solution? No.
In order to modify any of those properties I think that you will have to explode the blocks, after that modify the properties you need to modify and remake the block with the new properties!
Not quite a simple solution but I can't think at anything better at the moment!
With Respaect!
Csaba Arpad Dobai!
  • 2 years later...
Hi CAD89,
How do we know the number of times the object is nested? thanks
To answer your question, if all the entities in all the blocks are on layer "0" and color and linetype are set to "ByLayer" then any changes to the porperties of the base block will affect all the entities in all the nested blocks. The "SetByLayer" command should fix an existing block for you but I'm not sure if it was available in LD2009.
  • 4 weeks later...
