AJSmith Posted May 5, 2010 Share Posted May 5, 2010 can it be done i want the information in attributes to appear a number of time down a block as its size in increaced cheers Adam Smith Quote Link to comment Share on other sites More sharing options...
dbroada Posted May 5, 2010 Share Posted May 5, 2010 its not recommended. If you array an attibute it takes its TAG with it. While AutoCAD no longer goes off in a huff if you have the same attribute tag several times in the same block it will make any future LISP/VBA routine you throw at it run round in circles with unpredictable results. Quote Link to comment Share on other sites More sharing options...
