Am trying to set attributes to a block prior to insertion but cannot figure out how to set attributes.
Have worked with .getattributes but am unsure how to set them.
Hope someone can help.
Private Sub CommandButton4_Click()
Dim Array1 As Variant
Dim varInsertionPoint As Variant
Unload Me
With ThisDrawing.Utility
varInsertionPoint = .GetPoint(, vbCr & "Pick The Insertion Point: ")
End With
'Need to assign the following prior to inserting block
Array1(0).TextString = TextBox1.Value
Array1(0).color = ComboBox2.Value
Array1(0).Layer = ComboBox1.Value
Array1(1).TextString = TextBox2.Value
Array1(1).Layer = ComboBox1.Value
Array1(2).TextString = TextBox3.Value
Array1(2).Layer = ComboBox1.Value
ThisDrawing.ModelSpace.InsertBlock varInsertionPoint, "SRD20", 1, 1, 1, 0
End Sub
My VBA is lacking, but maybe something like:
Dim Insertion As Variant
Dim BlockObj As AcadBlockReference
Dim Attribs As Variant
Dim K As Integer
Set BlockObj = ThisDrawing.ModelSpace.InsertBlock(Insertion, "block", 1, 1, 1, 0)
Attribs = BlockObj.GetAttributes
For K = LBound(Attribs) to UBound(Attribs)
 Attribs(K).TextString = "Lee Mac"
Next K
Thanks for your quick response, just what I needed
