Hi people told me it It should be much easier to subract parts
from each other (without using derived component) If I have two blocks
mated to each other and a cylinder passing throug both of them, how do
I make the cylinder to cut through both parts so It would be a hole?
Multi-body solids. You can then push out to individual parts and assembly if needed (Manage tab).
You can also use Copy Object and Sculpt.
or
Multibody Solids (like JD mentioned and one of my favorites)
or
Adaptive Modeling with or without links to parts
Ok, I have my assembly in front of me containing three parts mated together, I open Manage tab, but where do I find Multi Body Solids?
... but where do I find Multi Body Solids?
There is an on-line class covering mutli-body solids here http://au.autodesk.com
Probably something in the Help>Learning Resources>Tutorials as well.
