Dear friends,
Can we unload lisp files from dwg?
Yours,
Muthu.
No, but you can redefine the functions ....
Ok.
But how can we know that what are the functions inside that lisp.
Is there anyway to find it?
yours,
Muthu
Use atoms-family function to list all existing symbols (variables and functions, both built-in and user defined) and using type function look for their type:
'USUBR = user defined routines loaded from LSP files
or
'SUBR = built-in routines or user defined routines loaded from FAS/VLX files.
Regards,
or
Regards,
Thank you. I will look at it and come back to you.
You welcome!
In order to discard a user function definition can assign nil to his symbol (name).
Regards,
You welcome!
Regards,
I have used the fuction "Atoms-only". But it returns a list having length of 4930.
How can i make all user defined fuctions and variables to nil?
Please help.
Not sure what you want to achieve with that…
It is about a routine developed by you? In this case just declare all variables as local and set nested function to nil.
If is a third-part, compiled, routine keep in mind that all symbols are discarded when the drawing is closed.
Regards,
