Change Profile from Command Line / Lisp??
I switch back and forth between two profiles all the time
and was wondering in it is possible to do this via lisp?
Wanting to create a shortcut to flip from one profile
to the other and back again as needed.
Something along the lines of Profile1 and Profile2.
Is it as simple as a setvar?
TIA!!
This should give you the information you're looking for. )
this is what i use for mt 2D and 3D profile switch
just change the 2D and 3D to your profile names
(vl-load-com)
(defun c:po (/ cpr)
 (if (= (getvar "cprofile") "3d")
   (setq cpr "2d")
   (setq cpr "3d")
 (if (= cpr nil)
   (setq cpr "2d")
 (vla-put-ActiveProfile
   (vla-get-Profiles
     (vla-get-Preferences (vlax-get-acad-object))
   cpr
) ;_defun
Untested...
(defun c:PTog (/ lst)
 (setq lst '("Profile1" "Profile2"))
 (vl-catch-all-apply
   (function vla-put-activeprofile)
   (list (vla-get-profiles (vla-get-preferences (vlax-get-acad-object)))
         (if (eq (getvar 'cprofile) (car lst))
           (cadr lst)
           (car lst)
 (princ (strcat "Active Profile: \"" (getvar 'cprofile) "\""))
Awesome guys!!
Only thing better than a solution is having multiple solutions...
Thanks much!
Awesome guys!!
Thanks much!
Makes life fun. :)
You're welcome.
