Andresig Posted May 12, 2010 Posted May 12, 2010 Hi, Is there a command in Autocad-Vba that you can turn on or turn off pop-up windows when you open or close a file? e.g.: prevent to open the window "File already exist. Do you want to replace it?" Quote
MikeScott Posted May 12, 2010 Posted May 12, 2010 You can change your Expert variable setting to deactivate that warning, but I'd advise turning it back on at the end of your program. Quote
MSasu Posted May 13, 2010 Posted May 13, 2010 If your issue is about accessing AutoCAD files by Visual Basic code, please be aware that Save, SaveAs and Close methods are overwriting without warning the existing files – for this reason you have to write your own code to warn user. Regards, Quote
Andresig Posted May 27, 2010 Author Posted May 27, 2010 My issue is when a file is open in some files appear the window asking me if I want to load a macro, thing that i don't want to do, I only want to open the file with out enabling any macro. Quote
