gib65 Posted May 12, 2010 Posted May 12, 2010 How can I create a rectangle that occludes everything behind it. I'm working in 2D. If I create a rectangle overtop already present geometry, I can still see that geometry through the rectangle (even if I make it into a region). There must be a way of filling the rectangle black. Is there? Quote
profcad Posted May 12, 2010 Posted May 12, 2010 Use the wipeout command. This will hide objects behind it. You can also use a solid hatch with the color white (color 255). Quote
lpseifert Posted May 12, 2010 Posted May 12, 2010 1. Use a Solid hatch 2. Use the Solid command (draw the 4 corners in a 'bowtie' fashion) 3. Use a polyline with a width Quote
