Ah!
Its because I'm on Vista....
SerialNumber
Data type: string
Access type: Read-only
Number allocated by the manufacturer to identify the physical media.
Example: WD-WM3493798728
Windows Server 2003, Windows XP, Windows 2000, and Windows NT 4.0:
This property is not available.
Missed that!
  • Replies 31
  • Lee Mac
    12
  • alanjt
    10
  • sharpooth
    6
  • JohnM
    3
Hi Lee,
when I am starting your code the rezult is
Command:
Command:
Command: (DiskDriveSerial)
(0 0 0)
when I am starting doslib:
Command: (dos_serialno "c")
"DC3DE5FA"
but my serial number is
Drive Serial Number_______________: 96352850172496771836
o:)
I wonder if it has to do with you running Vista.
Ah!
Missed that!
Deja vu:lol:
Sometimes another method isn't always the best method.
Sorry, but which did you use? The WMI method or the FSO?
I don't see your point - the data they retrieve is totally different.
Ahh, but when you posted you didn't specify that the return would be different. :wink: Also, the fact that it doesn't work on anything lower than Vista is a huge hindrance.
I made no reference to the Serial Number returned by the FSO when I posted, and furthermore, I don't see why you should dismiss my method, just because it does not work on your system - it may, after all, be that which the OP requested.
LoL
I never said one should dismiss anything, and it might just be what the OP wants. I was commenting on the lack of versatility.
Sorry Lee Mac about this problem
I just want to uderstand why there is a different...
Sorry again
Sharpooth,
The Serial as returned by the FSO/dosLib is that which is used by the system to identify the volume.
The Serial as returned by the WMI Query is that used by the Drive Manufacturer.
Sharpooth,
THANK YOU Lee Mac!!!
I know that you are the BEST!
:D
