Can someone help me understand the purpose of the Function - Lambda combination and what it does? :oops:
example from Lee Mac:
(vla-put-TextString
             (car
               (vl-remove-if-not
                 (function
                   (lambda (x) (eq "TREE#" (strcase (vla-get-TagString x)))))
                 (vlax-invoke Obj 'GetAttributes))) (car x))
I believe this is to set a block attribute, but I do not understand how it works...
Thanks
The function vl-remove-if-not takes a predicate function as an argument, along with a list argument.
vl-remove-if-not will then iterate through each member of the list argument and process each item though the predicate function, if the predicate function returns nil, the item will be removed (vice-versa for vl-remove-if).
The 'function' is to declare the lambda expression as a predicate function argument, and hence not to be evaluated. It has a few performance advantages over the use of an apostrophe.
See the VLIDE help file for more info.
Ok, Please speak slowly and use small words :oops:
Can you walk me through that bit of code to show me how it actually sets the attribite value? I guess I still don't quite get what it's doing
with the string.
The reason for all this is I am trying to use this to set 2 attributes (tags ID and BOTANICAL) in a revised version of your code.
I think I have the various values set to variables with the following:
(while (setq LINE  (car *lst*))
   (setq
       x (atof (nth 0 line))
       y (atof (nth 1 line))
       z (atof (nth 2 line))
       bNme (nth 3 line)
       ;;rot (dtr (atof (nth 4 line)))
       ; xscale (atof (nth 4 line))
       ; yscale (atof (nth 5 line))
       tnum (nth 4 line)
       species (nth 5 line)
       canopy (atof (nth 6 line))
   );end setq
(if (vl-catch-all-error-p
             (setq OBJ
               (vl-catch-all-apply (function vla-InsertBlock)
                 (list spc (vlax-3D-point (list x y z)) bNme 1. 1. 1. *ROT*))))
         (princ "\n** Error Inserting Block **")
           (vla-put-layer OBJ Lname)
           (vla-put-TextString
              (vl-remove-if-not
                 (function
                   (lambda (tnum) (eq "ID" (strcase (vla-get-TagString tnum)))))
                                   (vlax-invoke Obj 'GetAttributes)) tnum)
           (vla-put-TextString
              (vl-remove-if-not
                 (function
                   (lambda (botanical) (eq "botanical" (strcase (vla-get-TagString botanical)))))
                                   (vlax-invoke Obj 'GetAttributes)) botanical)
           (if (eq :vlax-true (vla-get-isDynamicBlock obj))
             (setq ValLst (mapcar 'cons '("CANOPY")
                    (mapcar
                      (function
                        (lambda (i)
                          (if (equal 0.0 (distof i) 0.0001) "1" i)))
                      (list (cadr LINE) (caddr x) (cadddr x)))))
                   (foreach dAtt (vlax-safearray->list
                               (vlax-variant-value
                                 (vla-GetDynamicBlockProperties obj)))
                 (if (setq tag (assoc (strcase (vla-get-propertyName dAtt)) ValLst))
                   (vla-put-value dAtt
                     (vlax-make-variant (cdr tag)
                       (vlax-variant-type (vla-get-value dAtt))))))))))
         ;;(princ (strcat "Tree# " (car x)))
       (setq *lst* (cdr *lst*)))
I am not sure if I have the second attribute set correctly (since I don't really inderstand how it does it...)
Thanks
Cary, please note that it is coding etiquette to note your revisions to someone else's code - else their work is tarnished.
Step by Step:
(vlax-invoke <BlockObject> 'GetAttributes)
==>  (<AttribObject> <AttribObject> <AttribObject> ... <AttribObject>)
(vla-get-TagString <AttribObject>)
==>  "TAG"
(vl-remove-if-not
 (function
   (lambda ( AttribObject )
     (eq "TAGSTRING"
       (strcase
         (vla-get-TagString AttribObject)
==> (<AttribObject>)
The GetAttributes method will returns the AttributeObjects (in a list if used with vlax-invoke), and this list is then iterated using vl-remove-if-not.
Each Attribute Object is tested within the predicate function, and the resultant list is returned.
Very sorry:oops:
I am still new to coding
Very sorry:oops:
No worries, just giving the heads up :)
