Hi Guys,
I have some query on how to create the attached image so that, when I bring it to the Presentation .ipn I am able to tweak each segment.
How I draw this:
1. Open a new .ipt
2. Create a sketch "Pipe Line" start point 0,0, Exit sketch
3. Create another sketch "Circle" on "XZ" plane point 0,0., Exit sketch
4. Invoke "Sweep" tool select "Circle" path "Pipe Line".
5. Create another sketch (to serve as a "Split Solid" tool).
6. Invoke "Split" tool and do the Split process.
Now, when I bring it over to the "Presentation" .ipn, I am not able to tweak each segment...:(
What is the right way to do it. So that, it will allow me to Tweak each segment.
Do I have to draw it 1 by 1!!!
Thanks in advance for the effort exerted on helping me on this matter.
When you Split the parts make sure you select the option to create New Solid so that you end up with a multi-body solid. Then on the Manage tab push out the individual parts to an assembly. Use the assembly in the ipn.
Wow... thanks JD appreciate it so much... You're a genius indeed...
