bamaman83 Posted August 28, 2008 Posted August 28, 2008 I feel silly for posting this but I find it very useful and I hope someone else will to. If you have to trim or extend to make a corner, just set your fillet radius to zero and that will do the trick. I know most of you probably already know this, but I just found out and I think it is really going to save me a ton of time at my new job. I am almost embarrassed to say what I was doing in these situations. I also think that the chamfer command will do the same thing. Maybe this will help somebody. Quote
tzframpton Posted August 28, 2008 Posted August 28, 2008 I feel silly for posting this but I find it very useful and I hope someone else will to. If you have to trim or extend to make a corner, just set your fillet radius to zero and that will do the trick. I know most of you probably already know this, but I just found out and I think it is really going to save me a ton of time at my new job. I am almost embarrassed to say what I was doing in these situations. I also think that the chamfer command will do the same thing. Maybe this will help somebody. To add to this tip, you don't even have to set the fillet radius to Zero - just hold Shift and pick your two lines and that defaults to Zero so you can retain your fillet radius. Quote
Gar Posted September 15, 2008 Posted September 15, 2008 StykFacE, Thank you for adding that! I didnt know that shift does that when filleting... Now how do i get back all the time that i have wasted setting the fillet, setting to 0, then resetting radius.... ugh Quote
Fritz Posted October 13, 2008 Posted October 13, 2008 I do the exact same thing except with chamfer, works the same way. Though I suppose "F" is quicker to type than "CHA" Quote
AlinOz Posted February 28, 2009 Posted February 28, 2009 Beauty - that's nice to know. Here's another one along the same vein - Trim and Extend Commands... Were you aware that if you use either of these, the Shift key will transpose the command? Let me explain - You have the typical scenario where lines extend past a 'cutting' object and others that don't reach it and you want both sets to end at the cutting line. Once upon a time we had to use both the TRIM and EXTEND commands. In this example we'll use the TRIM command wherin normally we 'cut off' the longer lines, while still in the command, hold down the Shift key and select the shorter ones and they will extend to the line. Now, you can use either command to handle both options in one command:D Quote
warlock Posted March 22, 2009 Posted March 22, 2009 Nice one,its going to be handy cheers Beauty - that's nice to know. Here's another one along the same vein - Trim and Extend Commands... Were you aware that if you use either of these, the Shift key will transpose the command? Let me explain - You have the typical scenario where lines extend past a 'cutting' object and others that don't reach it and you want both sets to end at the cutting line. Once upon a time we had to use both the TRIM and EXTEND commands. In this example we'll use the TRIM command wherin normally we 'cut off' the longer lines, while still in the command, hold down the Shift key and select the shorter ones and they will extend to the line. Now, you can use either command to handle both options in one command:D Quote
Ryder76 Posted May 1, 2009 Posted May 1, 2009 In the CUI if you change the chamfer command to look like this: ^C^C_chamfer;u; you won't have to select Multiple every time you want to use it. Works for fillet too. I'm a lazy cadder and to me less is more. Quote
rash214 Posted August 1, 2009 Posted August 1, 2009 ..hi everyone.. im new to autocad commands but im willing to learn.. more hopefully.. can you tell me how to do the zero degree fillet.. one baby step at a time.. thanks for the effort... alot.. Quote
tzframpton Posted August 1, 2009 Posted August 1, 2009 Holding the Shift key after you initiate the FILLET command will default the radius to zero. Quote
DVDM Posted August 6, 2009 Posted August 6, 2009 If you hold SHIFT while filletting two parallel lines, it joins the two with an arc. Quote
eldon Posted August 6, 2009 Posted August 6, 2009 If you hold SHIFT while filletting two parallel lines, it joins the two with an arc. You do not need to hold SHIFT with Fillet for joining parallel lines with an arc. Quote
mariay Posted September 11, 2009 Posted September 11, 2009 I have this problem that all my polylines in my drawing in autocad are in a different hights (elevation), anybody knows how can i make them all flat ? i need it flat so that when i import the file from sketchup i'll have normal lines thank u Quote
NuttZ Posted November 13, 2009 Posted November 13, 2009 I have used chamfer make my corners since ACA2004. I have 2010 and it doen't allow me to chamfer two AEC walls. It says it must be a line. any thoughts? Quote
AlinOz Posted November 13, 2009 Posted November 13, 2009 I have this problem that all my polylines in my drawing in autocad are in a different hights (elevation), anybody knows how can i make them all flat ? i need it flat so that when i import the file from sketchup i'll have normal lines thank u The quickest way is to select them all when you're at the 'Command' prompt (i.e. get the Grips on them). Then go to the properties dialogue wherein it should say that elevation varies. Change that to 0 and they'll all drop back. If it is greyed out, one of the polylines probably isn't parallel to the current UCS - select a smaller group of Polylines and try again. Repeat until you find the culprit and deal with him seperately... Hope that helps Quote
