youflyifix Posted May 18, 2010 Posted May 18, 2010 I am running XP pro 64. I have installed AC 2010 and then installed Adobe Acrobat 9. I am unable to pull up the adobe toolbar in CAD. When running the load ap I get an “acad.exeUnable to laod PDFMACad.arx file.” Anyone have an idea for a fix or work around? Quote
chulse Posted May 19, 2010 Posted May 19, 2010 I'm not sure it's supported in the newer versions of AutoCAD. You should still be able to plot to "Adobe PDF" via the plot dialog, right? Quote
youflyifix Posted May 24, 2010 Author Posted May 24, 2010 Yes I can use the plot, but it was a much better tool when I could plot all the layouts at once and adjust their placement. Quote
SPARKY77 Posted May 24, 2010 Posted May 24, 2010 You can still plot all the layouts using the publish tool Quote
chulse Posted May 24, 2010 Posted May 24, 2010 You can still plot all the layouts using the publish tool Ditto that Quote
ILoveMadoka Posted December 2, 2010 Posted December 2, 2010 The Adobe solution is much better and easier by far! IMO I know about Publish as well but does anyone know whether has Adobe just stopped supporting Autocad or is something in the works or should we all just give up hope or bend over or turn our heads and cough or what? Just wondering as well! Thx! Quote
