kibenz Posted May 18, 2010 Posted May 18, 2010 Hello everybody, I'm working on my thesis topic to spatial data management (primarily through the meta data management (MDM) => Management of data about data)). The work is produced in cooperation with a company that uses the Autodesk Vault for data management. AutoCAD Civil 3D and ArcGIS are used for further work . My job will be to build a meta information system for an ongoing project that can facilitate the management of metadata. As an established DMsystem I have the impression, that AD Vault is not good for metadata management. Now my question to you, please ...: Can I import the data from AD Vault and from ACAD and the data metadata in ArcGIS edit with the ArcCatalog and then publish through ArcIMS? Or are there other options? I would be happy to answer your lot. Greetings, Kibenz Quote
