Multiple command .Lisp Routine Advice pls.
If it is possible i will go away and try write it myself, :unsure:
just wondering, we've come across a problem at work sice upgrading from 2004 to 2008, and the only way to fix it is by opening every dwg and following steps in attatched pdf.
Is it possible for a lisp routine to be written to do this and then assigned to a button of your choosing?
Thanks in advance
Skipsophrenic the nutter:D
AutoCAD 2008 Glitch fix.pdf
firstly, I don't think you need to repeat every step in those instructions. Where it says "repeat steps x-x" you should be able to use the "previous" selection set.
this should give you a clue as to how to address the problem. you need to create a selection set in either LISP or VBA - each allows you to build filters to ensure you only get the text you require. From there on it is (it seems) quite simple - not that I'm offering to do it.
I have not seen this particular problem (at least not noticed it!) so I wait to see your efforts and hope I don't need it.
all it is, is that the mtext has "Covered the drawing", with too high defined height. but still needing to do the other steps to get the drawing back (annoying) I hope nobody else needs to puzzle it out either, we think its to do with how ACAD 2008 deals with mtxt vs how ACAD 2004 does. (Why do autodesk change a perfectly good platform.)
and don't worry - i'm not gonna ask anybody else to write the code for me - maybe tell me where i gone wrong, but not write it, that would be cheating - I think :?
creating selection sets is well covered here, do a search. You may need a little help in defining the syntax but try selecting all MTEXT first - somebody will then be able to help with the MTEXT AND bits.
what language are you hoping to learn? LISP or VBA?
this may sound crazy :wacko:
but i'm hoping to learn both (Not at same time though! LOL):lol:
and have you started with either yet?
The following is a bit of VBA that will select ALL MText within the drawing. I can't work out in your routine why you should select text NOT of a certain colour rather than all text - any ideas?
Having made your selection set you can perform actions on that set. What I can't find is how to set "Defined Height" though. It must be possible but I can't see it. It may only be available through LISP.
Public Sub BangMText()
'Dim myObject As Object
Dim mySelectionSet As AcadSelectionSet
Set mySelectionSet = ThisDrawing.SelectionSets.Add("MText")
Dim gpCode(0) As Integer
Dim dataValue(0) As Variant
Dim groupCode As Variant
Dim dataCode As Variant
gpCode(0) = 0 'item
groupCode = gpCode
dataValue(0) = "MTEXT" 'item type
dataCode = dataValue
mySelectionSet.Select acSelectionSetAll, , , groupCode, dataCode
Debug.Print mySelectionSet.Count
ThisDrawing.SelectionSets.Item("MText").Delete
End Sub
Deletes all not Red MText.
Public Sub DeleteNotRedMText()
[color="Blue"]Dim filCode(0 To 3) As Integer[/color]
[color="#0000ff"]Dim filVal(0 To 3) As Variant[/color]
Dim cTxt As AcadMText
[color="#0000ff"]filCode(0) = 0: filCode(1) = -4: filCode(2) = 62: filCode(3) = -4[/color]
[color="#0000ff"]filVal(0) = "MTEXT": filVal(1) = "<NOT": filVal(2) = 1: filVal(3) = "NOT>"[/color]
mySelectionSet.Select acSelectionSetAll, , , filCode, filVal
For Each cTxt In mySelectionSet
   cTxt.Delete
Next cTxt
End Sub
End Sub[/code]
Because that was the only way i could figure out how to select the mtext and not normal text as well, (Maybe i need a refresher cousre on cad full stop:? )
Thnks to you, the best part of the lot is all of the code that i have written so far is two lines
using QSELECT you can select MTEXT from the Object type and use an operator of select all.
I took your instructions at face value assuming you had found them somewhere. How much of that do you actually have to do? "Defined Height" appears to be the height of the text box, not the text itself so shouldn't really "cover the drawing". Another thing, do you need to move the text by an amount? Can't you just move it by 0?
Can you post a "damaged" drawing so that i can have a look as I haven't encountered this problem yet. (I do have a different one with text though)
i'll have to wait untill i get home 'cos i havent got a copy here at work at the moment. (Wish i had)
and unfortunately i didn't find those instructions, i was asked to type them up so as could be distributed around our office
RE: QSELECT comment :oops: NOW I FEEL DAFT!!! one of basic things i should have known!
ok, a lot of what you are doing is not needed. I assume you are trying to get rid of the vertical "stripes" created by the MTEXT?
How about:
select all MTEXT (QSELECT)
set defined height = 0 (use properties)
save drawing
Next time you open the drawing it will have done all the regeneration needed.
ok, now i feel dumb,:oops: thnx 4 remindin me the quick way dbroadba, :thumbsup:
(i always overcomplicate things - that what said in last review anyway)
I have been the same for years. However, changes are a neccesary evil
If it didn't update it would die out. My acad skills become redundant
When it updates, My acad skills become redundant
FOUND THE PROBLEM! The background mask in mtext was set to somethin RIDICULOUS, after qselecting everythin, i just turned off the background mask, and problem go bye-bye
