arshavin23 Posted May 19, 2010 Posted May 19, 2010 Does anyone know how to apply a drive constraint between two gears so that they will rotate in an animation? I have been trying applying an angle constraint between one gear's shaft and the grounded component which is an electric motor. S Quote
arshavin23 Posted May 19, 2010 Author Posted May 19, 2010 Got it working, sorry for the wasted post... Rather than applying an angle constraint to one gears plane, i was applying it to the gear itself. I applied an angle constraint from a plane on the gear to the grounded component which in my case was the gear box cover. This then allowed me to drive the constraint and show the gears animate. Quote
