harrison-matt Posted May 20, 2010 Posted May 20, 2010 Hey, Does anyone know the format or syntax of exporting to dxf in VB.Net? Autodesk.Revit.CADExportOptions Or just some help on VB.Net will work! Thanks, Matt Quote
bsamc2000 Posted February 24, 2017 Posted February 24, 2017 I'm not sure about Revit but with most Autodesk products you can use something like the following. Call oDrawDoc.SaveAs(oPath & "\PDF\" & oName & ".pdf", True) Quote
