geogiac Posted May 21, 2010 Posted May 21, 2010 does anybody has a snippet of code thata does the following (completely out of process because i want to make an EXE that commands autocad) 1- open a transaction 2- activate a drawing 3- add a line in the database and in the modelspace 4 - closes the connection thanks Quote
SEANT Posted May 21, 2010 Posted May 21, 2010 Hooking onto AutoCAD from an out of process application requires the use of a COM Interop, hence a “Transaction” will not be available. Fortunately, there is still a lot of manipulation available through that COM/ActiveX hook. Post #17 of this thread has an example establishing a COM hook. http://www.cadtutor.net/forum/showthread.php?t=39166 While it doesn’t actually add anything to a drawing database, it does show how to acquire the AutoCAD application. Entities can be added to a Block Table Record (i.e., Modelspace, Layout, etc.) in the same manner as shown in the AutoCAD Developer Help: ActiveX and VBA Reference. Quote
