any one know a lisp to click at a point and read xyz after that it convert that corrdinat to mtext
  • Replies 23
  • Lee Mac
    8
  • aryanarch
    4
  • ttsadaf
    2
  • stevesfr
    2
Quick one:
(defun c:mpt (/ M-Point M-Text pt)
 (defun M-Point (pt)
   (entmakex (list (cons 0 "POINT") (cons 10 pt))))
 (defun M-Text (pt val)
   (entmakex (list (cons 0 "MTEXT")
                   (cons 100 "AcDbEntity")
                   (cons 100 "AcDbMText")
                   (cons 10 pt)
                   (cons 1 val))))
 (while (setq pt (getpoint "\nPick Point: "))
   (M-Point (setq pt (trans pt 1 0)))
   (M-Text pt
     (apply 'strcat
       (mapcar 'strcat '("X = " "\nY = " "\nZ = ") (mapcar 'rtos pt)))))
 (princ))
hi lee mac
can u change the text height or rotation of the mtext in this code
because i made a new text style and new layer, i made the to the current, but it is not working with this text style..
Quick one:
 (defun M-Point (pt)
                   (cons 10 pt)
                   (cons 1 val))))
   (M-Text pt
     (apply 'strcat
 (princ))
The original code will take on the properties of the current textstyle, but this will give you manual control:
(defun c:mpt (/ M-Point M-Text pt height rotation)
 (setq height 2.5 rotation 0.0) [color=Blue][b];; Text Height and Rotation[/b][/color]
 (defun M-Point (pt)
 (defun M-Text (pt val hgt rot)
                   (cons 10 pt)
                   (cons 1 val)
                   (cons 40 hgt)
                   (cons 50 rot))))
   (M-Text pt
     (apply 'strcat
           height rotation))
 (princ))
 (setq height 2.5 rotation 0.0) [color=blue][b];; Text Height and Rotation[/b][/color]
 (defun M-Point (pt)
                   (cons 10 pt)
                   (cons 1 val)
                   (cons 40 hgt)
                   (cons 50 rot))))
   (M-Text pt
     (apply 'strcat
           height rotation))
 (princ))
How to change output to Y, X, Z instead? :(
 (setq height 2.5 rotation 0.0) ;; Text Height and Rotation
 (defun M-Point (pt)
                   (cons 10 pt)
                   (cons 1 val)
                   (cons 40 hgt)
                   (cons 50 rot))))
   (M-Text pt
     (apply 'strcat
       (mapcar 'strcat '("Y = " "\nX = " "\nZ = ")
         (mapcar 'rtos (list (cadr pt) (car pt) (caddr pt)))))
           height rotation))
 (princ))
 (defun M-Point (pt)
                   (cons 10 pt)
                   (cons 1 val)
                   (cons 40 hgt)
                   (cons 50 rot))))
   (M-Text pt
     (apply 'strcat
           height rotation))
 (princ))
Lee, thanks for the lesson on the use of rtos ! now I can fix all my other resulting "xyz" programs to "yxz" (which for me is N,E,Elev) !!
very well ...............
beautiful lisp routines.........
awesome..........
tahnx very much friends.......
awesome..........
You're welcome :)
when i choose break at point in auto cad and i repeat this command by pressing enter or space it change the command to break. how to remain it to do break at point? thank u
Here my function, which write geodetic coordinates on leader
(defun c:geo_koord_leader (/ pod_z koord y x z xyz)
 (initget "Yes No")
 (setq
   pod_z (getkword "\nShow Z [Yes/No] <No>? : ")
 (while (and
     (setq koord (getpoint "\nPoint <Exit>"))
   (setq
     y   (strcat "X=" (rtos (nth 0 koord) 2 3))
     x   (strcat "Y=" (rtos (nth 1 koord) 2 3))
     z   (if
    (= pod_z "Y")
     (strcat "Z=" (rtos (nth 2 koord) 2 3))
   (VL-cmdf "_leader" koord pause "" x y z "")
(princ "Command name: geo_koord_leader")
  • 1 month later...
Hello!
Is there some possibility to change the numerological order? To be more specific: there is need in placing numbers beginning from north-west around the closed polyline (rectangle) instead of start point of polyline.
Will be very grateful for replies )
yes very nice lisp.....
but this lisp is giving the coordinates like (y,x)
it vl be more better if u make it (x,y) .......
waiting for your reply........
i want to say that it is giving y coordinates first and x coordinates next.......
can u make it to give it x coordinates and then y coordinates........
Well, simply I have got confused that X increases upwards (by the North) at us at geodesists, the same X to the right (on the East) in mathematical system of co-ordinates.
Therefore here two codes
1) For geodesists ↑x
 (initget "Yes No")
 (setq
 (while (and
   (setq
     y   (strcat "Y=" (rtos (nth 0 koord) 2 3))
     x   (strcat "X=" (rtos (nth 1 koord) 2 3))
     z   (if
    (= pod_z "Y")
2) For all other normal people →x :)
(defun c:math_koord_leader (/ pod_z koord y x z xyz)
 (initget "Yes No")
 (setq
 (while (and
   (setq
     x   (strcat "X=" (rtos (nth 0 koord) 2 3))
     y   (strcat "Y=" (rtos (nth 1 koord) 2 3))
     z   (if
    (= pod_z "Y")
(princ "Command name: math_koord_leader")
Are you referring to my program suggestion or GeoBuilder's LISP?
  • 3 weeks later...
Great codes guys..
Thanks a lot.
