I am using autocad 2002 on an HP laptop w/ windows xp pro.
I have used this for years performed like a swiss watch. I had to re install windows xp and acad 2002 now when I look at my screen in autocad all the circles look like ovals and I plot in model space so I have my 24 x 36 borders and title blocks in the drawing and they are squished and distorted stretched left and right. I suspect it has something to do with my video card but everything else displays fine?
Your aspect ratio is off for your monitor... Your monitor will have certain (maybe several), resolutions with the correct aspect.
Best way is to just create a circle in Autocad and adjust your resolution until it looks good to you...
KC
KC
where do I set aspect ratio? in CAD or xp? if so how?
In XP...
Right click on main desktop window >> Select properties
Click on Settings Tab
Adjust the slider...
KC
In XP...
KC
thanks KC I tried that and the slider only gives me the 2 extremes far left or far right neither will work right.
You need to re-install your Display adapter Driver. Either from a disk or online. Go to the manufactures web page for your adapter and update.
On the same screen you were before click "Advanced" >> "Adapter" Tab... This will display the adapter information. Click properties to update driver if you can't find online...
KC
KC
figured something like that as when I open adapter tabs all boxes say nothing is there or no info. I'll contact the guy that built the laptop and see what video and adaptor he put in see how to install driver, I have the same problem with wireless modem availability --nothing there. This is a custom built HP so tech should have info for me thanks KC
