numberOCD Posted May 27, 2010 Posted May 27, 2010 How would I set a stretch action in a dynamic block to stretch in increments of 0.1in? (without setting the grid on the model, because this method will be used for many blocks with different increments.) Quote
JD Mather Posted May 27, 2010 Posted May 27, 2010 Search here http://au.autodesk.com for Matt Murphy on-line classes. He demostrates how to do what you want. (it is pretty easy) Quote
numberOCD Posted May 27, 2010 Author Posted May 27, 2010 This isn't a detail I can really write off as an expense here. If you've got any tips, I could really use them Quote
tzframpton Posted May 27, 2010 Posted May 27, 2010 How would I set a stretch action in a dynamic block to stretch in increments of 0.1in? (without setting the grid on the model, because this method will be used for many blocks with different increments.) Select the Parameter you have the Stretch Action set to, and open the Properties palette... the option to increment is in the Value Set option. Quote
numberOCD Posted May 27, 2010 Author Posted May 27, 2010 Thank you greatly StykFacE! Works great! Quote
