Hi All,
I inserted a dynamic block in the screen and I want to change the visibility list of it.
I was thinking it should be very straight forward but it is not easy apparently!
Anyway, I start to collect information about the block but I can't understand how can I find and change the visibility parameter out of those information!
I wrote:
(defun c:test ()
(vl-load-com)
(setq e (car (entsel)))
(setq obj (vlax-ename->vla-object e))
(setq propname (vla-GetDynamicBlockProperties obj)) ;Get the parameters
(setq var (vlax-variant-value propname)) ;Convert variant to SafeArray
(setq numd (vlax-safearray-get-dim var)) ;Returns the number of dimensions in a safearray object
(setq lis (vlax-safearray->list var)) ;Convert safearray to list
(print e)
(print obj)
(print propname)
(print var)
(print numd)
(print lis)
and I get:
Command: test
Select object:
1
I attached the file as well.
Can you please help me with that?
Cheers
Ali
Test.dwg
Hi All,
I wrote:
and I get:
Cheers
Ali
Not sure if this is what you are after. See link: http://www.cadtutor.net/forum/showthread.php?t=41059&highlight=visibility+STATE
  • 2 weeks later...
