kevynm Posted May 29, 2010 Posted May 29, 2010 Help!! While working in Autocad 2011, I had a power cut. After rebooting the system, everytime I start Autocad 2011 I get a message "the customization file you are trying to load is invalid.Swelect a diff customization file and try again." on clicking ok 3 times I get another message "unhandled exception has occured in your application......Configuration system failed to initialize." the details are: Application does not support just-in-time (JIT) debugging. See the end of this message for details. ************** Exception Text ************** System.Configuration.ConfigurationErrorsException: Configuration system failed to initialize ---> System.Configuration.ConfigurationErrorsException: Root element is missing. (C:\Users\kev\AppData\Local\Autodesk,_Inc.\DefaultDomain_Path_bwycswj4l0mijpdw3ttamfd5sbysqavn\R18.1.49.0.0\user.config) ---> System.Xml.XmlException: Root element is missing. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.ThrowWithoutLineInfo(String res) at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at System.Xml.XmlTextReaderImpl.Read() at System.Xml.XmlTextReader.Read() at System.Configuration.XmlUtil..ctor(Stream stream, String name, Boolean readToFirstElement, ConfigurationSchemaErrors schemaErrors) at System.Configuration.BaseConfigurationRecord.InitConfigFromFile() --- End of inner exception stack trace --- at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal) at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors) at System.Configuration.BaseConfigurationRecord.ThrowIfInitErrors() at System.Configuration.ClientConfigurationSystem.OnConfigRemoved(Object sender, InternalConfigEventArgs e) --- End of inner exception stack trace --- at System.Configuration.ConfigurationManager.PrepareConfigSystem() at System.Configuration.ConfigurationManager.GetSection(String sectionName) at System.Configuration.PrivilegedConfigurationManager.GetSection(String sectionName) at System.Diagnostics.DiagnosticsConfiguration.GetConfigSection() at System.Diagnostics.DiagnosticsConfiguration.Initialize() at System.Diagnostics.DiagnosticsConfiguration.get_Sources() at System.Diagnostics.TraceSource.Initialize() at System.Net.Logging.InitializeLogging() at System.Net.Logging.get_On() at System.Net.WebRequest.Create(Uri requestUri, Boolean useUriBase) at System.Net.WebRequest.Create(Uri requestUri) at MS.Internal.WpfWebRequestHelper.CreateRequest(Uri uri) at System.Windows.Media.Imaging.BitmapDecoder.SetupDecoderFromUriOrStream(Uri uri, Stream stream, BitmapCacheOption cacheOption, Guid& clsId, Boolean& isOriginalWritable, Stream& uriStream, UnmanagedMemoryStream& unmanagedMemoryStream, SafeFileHandle& safeFilehandle) at System.Windows.Media.Imaging.BitmapDecoder.CreateFromUriOrStream(Uri baseUri, Uri uri, Stream stream, BitmapCreateOptions createOptions, BitmapCacheOption cacheOption, RequestCachePolicy uriCachePolicy, Boolean insertInDecoderCache) at System.Windows.Media.Imaging.BitmapDecoder.Create(Uri bitmapUri, BitmapCreateOptions createOptions, BitmapCacheOption cacheOption, RequestCachePolicy uriCachePolicy) at System.Windows.Media.Imaging.BitmapDecoder.Create(Uri bitmapUri, BitmapCreateOptions createOptions, BitmapCacheOption cacheOption) at Autodesk.Private.Windows.RibbonUtil.LoadImage(Uri uri) at Autodesk.Private.Windows.RibbonImageSource.LoadImage() at Autodesk.Private.Windows.RibbonImageSource.get_LoadedImage() at Autodesk.Windows.RibbonItem.get_ImageOverride() at Autodesk.Windows.RibbonItem.CopyFrom(RibbonItem source) at Autodesk.Windows.RibbonCommandItem.CopyFrom(RibbonItem source) at Autodesk.Windows.RibbonButton.CopyFrom(RibbonItem source) at Autodesk.Windows.RibbonItem.System.ICloneable.Clone() at Autodesk.Windows.RibbonItem.Clone() at Autodesk.AutoCAD.Internal.Windows.QuickAccessToolbarService.AddAllStandardItems() at Autodesk.AutoCAD.Internal.Windows.QuickAccessToolbarService.LoadContent() at Autodesk.AutoCAD.Internal.Windows.QuickAccessToolbarService.RestoreItems() at Autodesk.AutoCAD.Internal.Windows.QuickAccessToolbarService.Initialize() at Autodesk.AutoCAD.Internal.Windows.QuickAccessToolbarService.LoadQuickAccessToolbar() at Autodesk.AutoCAD.Internal.Windows.QuickAccessToolbarService.OnApplicationIdle(Object sender, EventArgs e) at System.EventHandler.Invoke(Object sender, EventArgs e) at Autodesk.AutoCAD.ApplicationServices.Application.raise_Idle(Object value0, EventArgs value1) at Autodesk.AutoCAD.ApplicationServices.Application.OnIdle() ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4200 (NetFxQFE.050727-4200) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- acdbmgd Assembly Version: 18.1.0.0 Win32 Version: 18.1.49.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcdbMgd.DLL ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4016 (NetFxQFE.050727-4000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- msvcm90 Assembly Version: 9.0.30729.4148 Win32 Version: 9.00.30729.4148 CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4148_none_5090ab56bcba71c2/msvcm90.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4016 (NetFxQFE.050727-4000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4016 (NetFxQFE.050727-4000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- PresentationFramework Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.4000 built by: QFE CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll ---------------------------------------- WindowsBase Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.4000 built by: QFE CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll ---------------------------------------- PresentationCore Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.4000 built by: QFE CodeBase: file:///C:/Windows/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll ---------------------------------------- AdApplicationFrame Assembly Version: 0.0.0.0 Win32 Version: 3.0.264.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AdApplicationFrame.DLL ---------------------------------------- AdWindows Assembly Version: 3.0.263.0 Win32 Version: 3.0.263.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AdWindows.DLL ---------------------------------------- PresentationFramework.Classic Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.4000 built by: QFE CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Classic/3.0.0.0__31bf3856ad364e35/PresentationFramework.Classic.dll ---------------------------------------- acmgd Assembly Version: 18.1.0.0 Win32 Version: 18.1.49.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/acmgd.DLL ---------------------------------------- System.Core Assembly Version: 3.5.0.0 Win32 Version: 3.5.30729.1 built by: SP CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4016 (NetFxQFE.050727-4000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- AcWindows Assembly Version: 18.1.0.0 Win32 Version: 18.1.49.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcWindows.DLL ---------------------------------------- AcWindows.resources Assembly Version: 18.1.0.0 Win32 Version: 18.1.49.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/en-US/AcWindows.resources.DLL ---------------------------------------- AcCui Assembly Version: 18.1.0.0 Win32 Version: 18.1.49.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcCui.DLL ---------------------------------------- CsMgdAcad3 Assembly Version: 1.0.3694.29232 Win32 Version: 1.0.3694.29232 CodeBase: file:///C:/Program%20Files/Autodesk%20Research/CommunityCommands/CsMgdAcad3.dll ---------------------------------------- CommunityCommands1 Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Program%20Files/Autodesk%20Research/CommunityCommands/CommunityCommands1.DLL ---------------------------------------- ContextualTabSelectorRules Assembly Version: 0.0.0.0 Win32 Version: 18.1.49.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcWindows.dll ---------------------------------------- AcCustomize Assembly Version: 18.1.0.0 Win32 Version: 18.1.49.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcCustomize.DLL ---------------------------------------- AcCustomize.resources Assembly Version: 18.1.0.0 Win32 Version: 18.1.49.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/en-US/AcCustomize.resources.DLL ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4016 (NetFxQFE.050727-4000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- ManagedMC3 Assembly Version: 4.11.0.0 Win32 Version: 4.12.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/ManagedMC3.DLL ---------------------------------------- ************** JIT Debugging ************** Application does not support Windows Forms just-in-time (JIT) debugging. Contact the application author for more information. On trying to reload Autocad there is no repair option. Please help I need Autocad up and running within 9 hrs. pls pls help Quote
kencaz Posted May 29, 2010 Posted May 29, 2010 On trying to reload Autocad there is no repair option. Please help I need Autocad up and running within 9 hrs. pls pls help I believe you will only have an option to repair Autocad from the control panel Uninstall applications not during initial installation. KC Quote
MikeScott Posted May 29, 2010 Posted May 29, 2010 Call autodesk.. Optionally, reinstall Autocad.. it's likely that they'd tell you to do that anyways, assuming there's no "repair" in the add remove/programs area in the control panel, like KC suggested.. Quote
RMacapinlac Posted July 29, 2010 Posted July 29, 2010 System.Configuration.ConfigurationErrorsException: Configuration system failed to initialize ---> System.Configuration.ConfigurationErrorsException: Root element is missing. (C:\Users\kev\AppData\Local\Autodesk,_Inc.\Default Domain_Path_bwycswj4l0mijpdw3ttamfd5sbysqavn\R18.1 .49.0.0\user.config) ---> System.Xml.XmlException: Root element is missing. - Just delete the said configuration file from the error message (i.e. C:\Users\kev\AppData\Local\Autodesk,_Inc.\Default Domain_Path_bwycswj4l0mijpdw3ttamfd5sbysqavn\R18.1 .49.0.0\user.config). AutoCAD should launch correctly after that. Quote
