Hmmm... currently the program will save a temporary script file which it proceeds to read when the script is run.
But, I suppose I could make the 'Save' button prompt for a location, then write out the .SCR file to that location.
And similarly, I suppose I could have a browse button on the load dialog so that the user could select an existing .SCR file to load, and the program would read the first line of the script and replace the filename automatically with the *file* delimiter for use with the program.
Some nice ideas,
Lee
  • Replies 46
  • Lee Mac
    21
  • asos2000
    8
  • The Buzzard
    5
  • jgmechengr19
    4
Posted Images
I have updated the first post to Version 1.2, the program will now save Scr files to a user specified location should the user decide to hit 'Save'.
Also, the user can load an existing Scr file using the 'Browse' button when using the 'Load' dialog. This will import the file so that it is in a format that can be used by the program.
Enjoy, and if you have any questions regarding the operation of the program, just ask.
Lee
I decided to update my old 'script writer' code to make the program a lot more user friendly.
Being an LT user I get mixed messages about whether a script creator will work. (There is no definitive test to know if it will not work, or I just set it up wrong!)
I have been told that scriptpro WILL work on LT, though I could not get it to. Lee Mac, could you tell me if this will work on LT?
Hi Isaac,
No, I'm afraid this utilises VLISP/DCL which won't run on LT without an extender :(
script writer is a lisp and LT not runing the lisp
So, you will not be able to run this lisp
Asos, does the code import Scr Files correctly?
Thanks LEE
feedback
- *file* added at the end of script line not at the curser place. adding *file* next to loaded script.
- cant read this type of format when Enter used instead of space (see attached)
- Isn't better to add 2 bottuns, one for adding _.open *file* and another one for *file* _.close
up to my kowladge (and tell me if i am wrong) we have to add these 2 parts at the begining and at the end of script.
Hi Isaac,
Thanks Lee Mac and Asos.
Great work on the program though, it still looks excellent.
While I'm here, do you know if Scriptpro would be the same story with LT?
feedback
Hi Asos,
Many thanks for the feedback, it is appreciated.
The problem with the *file* button is that once the user clicks the 'Filename' button, the dialog focus is switched to that button, and the cursor position cannot be determined (in Standard DCL that is), before the action statements for that button are evaluated.
When importing the scripts - I assume that the script format is similar to that created by the program - i.e. processing one file per line, with the line being delimited by spaces.
I'm not sure about the extra buttons - I don't want to clutter the dialog, but I can see what you are saying. I just thought that the filename button would save the user from typing *file* - which, with all the asterisks, may get annoying.
Lee
:cry::cry:Dear friends,
still i am finding,how its working?...........I can't find the way of executing..pls some one help me...
1. Loaded script file, using load script
2.clicked file name,edit the text (myfirst drawing placed in that directory) need .dwg?
&token means?
3.clicked directory,selected path
4.clicked run script
its showing error msg..........
here attached my cad screen as well as drawings stored location can any one help me?......
Thankin you:):)
By
mani
The drawing filenames are written to the script automatically, using the files found in the directory you have selected.
You only need to include the first line of the script, and where the filename would usually be write: *file*.
The token *file* represents the filename in the script - this is exchanged for each of the filenames in the directory you have chosen when you run the script. The program saves time as you don't have to write all the filenames into the script, but only select a directory to process.
Example:
_.open *file* _.-la _off e-p-text-s ...
Let me know if you don't understand :)
Were you able to work the program in the end Mani?
eeemmmmm
Unbelievable idea
What about Edit saved script line by double click on it,
But
The script line editing will effect the saved *.scr file?
Or asking the user to resave?
Hasan
eeemmmmm
Unbelievable idea
But
Hasan
That's not really feasible since when loading the script file, the program reads the file and is not working directly from the file.
However, the user can load the script file, make their changes, then save and overwrite the old script file.
:(:(Now i understand the basic.........
its Working fine with Open saveas close script...in all the dwg placed in directory. but along with this my script is not working.
my need is want to layer off the "E-P-TEXT-S" layer in all the drawings.
pls anyone suggest the code (script)
1.open
2.layer off
3.saveas
4.close
Thanks in advance.............
mani:roll::roll:
Perhaps try something like this:
_.open *file* _.-layer _Off E-P-TEXT-S  _.saveas  *file* _.close
Dear LEE,:D:D:D:D:D:D
Now its working fine.......I am so happy while seen the success of program, then i was tried some of my own scripts. All are working.
its a wonderful , amazing , superb , classic , excellent .............never end
I am working one of the big project for last 2 years, so we are managing more than 500 files........at the time of submission we need to do small work (like layer off) in 100 drawings at pressure situation, that time onwards i am searching lisp like Script writer.........If i would got 2 years back, surely its save a valuable time. so now i am feeling like somebody getting life time achivement award......
Really Good one
Will hope your non stop performance........
Thank you once again..
Regards
mani :):):)
Excellent Mani, I'm happy that you could benefit from the program - it sounds like it will save you a lot of time over the years :)
  • 1 month later...
Hey Lee,
I was recommended to come check this out by The Buzzard. I am a little unsure how to use. I tried doing a simple thing like changing 'insunits' to 0 and that didn't work. lol.
_.open *file* _insunits 0 _.save *file* _.close
This is what I am trying to do though.
The company I work for makes many small parts and we need to add to a column in 'ambom' for over 2000 drawings. I want to know if its possible go into 'ambom' go to the 'Partid' column and type 'Special', then apply/ok, save the file and close it as well. I know your program will open/save/close the file, but is it able to do something like this. Maybe there is an easy LISP script I could make that would work. Let me know what you think.
p.s. each drawing already has the 'Partid' column, so it does not need to be created, only edited.
Kenter
Edited by Kenter
