Hi,
I hope someone can help.
I am trying to add a command button to a form. This button, when pressed will display an unlimited number (with in reason) of text boxes ,called TBxInt ready for the users input. The qty of the text box ‘TBxInt ‘ depends on the value held by another text box, called TBxVal.
For eg
if TBxVal.value = “9” then create TBxInpt(0-9)
TBxInpt.width = 8
TBxInpt(0).left = 0
TBxInpt(1).left = 10
TBxInpt(2).left = 20
Etc etc
The user can then input values into each text box and the values will be used for further calculations.
If anyone knows of any example or tutorials on this I would appreciate it
Many thanks,
col
In VB, this would be called a "Control Array", and its built in.
But in VBA, since we dont have Control Arrays, we'll make our own Array of Controls.
' in a blank VBA userform, drop in the following code, run the form,
'and click the form to have it create the controls on the fly.
' ---- snip -------- snip -------- snip -------- snip ----
Dim cmdButton() As MSForms.CommandButton
Private Sub UserForm_Click()
Dim numButtons As Integer: numButtons = 4
ReDim cmdButton(numButtons)
Dim I As Integer
For I = 0 To numButtons
' create a control on the fly
Set cmdButton(I) = Me.Controls.Add("Forms.CommandButton.1", "Command" & LTrim$(Str$(I)), True)
' set its position and size
cmdButton(I).Height = 20: cmdButton(I).Width = 100
cmdButton(I).Left = 5: cmdButton(I).Top = (I * 25) + 5
cmdButton(I).Caption = "Command " & I
Next I
' resize the form around the text boxes
Me.Width = 115
Me.Height = ((numButtons + 2) * 25)
End Sub
rocheey,
thank you i will give it a go!
cheers,
col
