PeterPan9720 Posted June 4, 2010 Share Posted June 4, 2010 Hi Guys I have the necessity to insert in a block the attribute of own x and y position in the modelspace. Is there a system variable to insert in the invisible block attributes ?. In this way may I manipulate the data of the blocks knowing his position. In the opposite case how to manipulate the the ATTOUT lsp in ACAD 2010 express tools to have the above information ? Thks. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 4, 2010 Share Posted June 4, 2010 How about using a FIELD within the attributes of the block, referencing its own position? As for the ATTOUT, why not use DATAEXTRACTION Quote Link to comment Share on other sites More sharing options...
PeterPan9720 Posted June 4, 2010 Author Share Posted June 4, 2010 How about using a FIELD within the attributes of the block, referencing its own position? As for the ATTOUT, why not use DATAEXTRACTION Thank you I tried to use DATAEXTRACTION but I was not able to send back to the blocks the manipulated data. if you can explain me where to find the field for X & Y pos and add as block attribute I'll appreciate. Thanks Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 4, 2010 Share Posted June 4, 2010 I'm not sure it'll work both ways - the Field will not manipulate the block's position, rather just read the information. Go to FIELD > Object > [select the block] > Position Copy/Paste the field code into the attrib Quote Link to comment Share on other sites More sharing options...
