petdem Posted June 4, 2010 Posted June 4, 2010 How do i place a edge on the top/bottom nut section on this stem.I tried by using Extrude command and selecting Intersect + 45 degree angle Taper.When i used this combination it places the Taper on the nut but removes the rest of the part.Can this be done or do i need to create the Nut and Taper first and then do sketches/Extrude for the rest. Cheers....Pete nut.zip Quote
JD Mather Posted June 4, 2010 Posted June 4, 2010 Always do the Hex extrusion first. Then the Extrude(s) taper intersection(s) Then finish the part cylindrical shaft(s). Your other option is to do a Revolve - Cut on the hex. Quote
