tjs131 Posted June 4, 2010 Share Posted June 4, 2010 Hi everyone My situation is that after installing autocad 2011 with no problem nor error messages, when I start the program for the first time and click the activation button, the licensing window appears blank. I close it and click again the activate button, and the autocad licensing window comes up blank, does some one can help. I'm using version 2009 and it's all fine and works perfectly, but cannot get the new version running, I have uninstalled it a few times and installed back again with no luck. Quote Link to comment Share on other sites More sharing options...
MikeScott Posted June 4, 2010 Share Posted June 4, 2010 Make sure your computer has the latest updates..? I'm guessing, but it seems like maybe some kind of Javascript failure or something, making the window appear blank? Is there stuff there that's not visible? Like buttons/links or something (ie- does your mouse cursor change as you move around the window?) Quote Link to comment Share on other sites More sharing options...
tjs131 Posted June 4, 2010 Author Share Posted June 4, 2010 Make sure your computer has the latest updates..? I'm guessing, but it seems like maybe some kind of Javascript failure or something, making the window appear blank? Is there stuff there that's not visible? Like buttons/links or something (ie- does your mouse cursor change as you move around the window?) No, the mouse cursor doesn't change when I move it around. The PC has the latest updates. The licensing window comes up blank, no image, nothing, after clicking the activate button...:cry::cry: Thanks for the reply MikeScott Quote Link to comment Share on other sites More sharing options...
sjain432 Posted June 30, 2010 Share Posted June 30, 2010 I was getting the same blank window after clicking the activate button. searched the net and found out that it was due to some javascript error and you have to re-register jscript.dll. I tried this and it worked for me. · Click Start · Click All Programs · Click Accessories · Right click Command Prompt · Click Run as Administrator · Enter the command, regsvr32 jscript.dll there will be a pop-up which will give you the success message. open up autocad and try activating it again. hope it works for you. cheers! Quote Link to comment Share on other sites More sharing options...
tjs131 Posted June 30, 2010 Author Share Posted June 30, 2010 SUPER!!!!!!!!!!!!!!!!!!! Thanks!!! Quote Link to comment Share on other sites More sharing options...
e_edram Posted September 4, 2010 Share Posted September 4, 2010 My problem is different, I cannot access to the activate screen. Here it is the image Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 4, 2010 Share Posted September 4, 2010 Unfortunately the image is nearly unreadable at least to me. Have you contacted your authorized AutoDesk reseller? Quote Link to comment Share on other sites More sharing options...
Ile Posted September 18, 2010 Share Posted September 18, 2010 My problem is different, I cannot access to the activate screen. Here it is the image[ATTACH]22876[/ATTACH] Hello, any solution for this problem ? Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 18, 2010 Share Posted September 18, 2010 What language packs have you loaded? Quote Link to comment Share on other sites More sharing options...
Ile Posted September 18, 2010 Share Posted September 18, 2010 Brasilian Portuguese, but I try in english too. Same problem. Is there any tip to completely uninstall ? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted September 18, 2010 Share Posted September 18, 2010 Is there any tip to completely uninstall ? http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=2887771&siteID=123112 Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 18, 2010 Share Posted September 18, 2010 Some users have found that a complete uninstall/reinstall does not solve the problem. I think it has something to do with an entry in the Registry that remains even after the uninstall. Find a reputable Registry cleaner (see PC World). Uninstall > create a Restore Point > run the Registry cleaner then reinstall AutoCAD. Quote Link to comment Share on other sites More sharing options...
Luiz Posted March 22, 2011 Share Posted March 22, 2011 Thank u very, very much!!!! =] Quote Link to comment Share on other sites More sharing options...
din_Dins Posted March 29, 2011 Share Posted March 29, 2011 BLANK WINDOW i did how "sjain432" said, for this jscript.dll it accepted and show succes message but anyway, when i read autoCAD, i have still this BLANK WINDOW. maybe you have another solution how can i activate? Quote Link to comment Share on other sites More sharing options...
Rishav Posted September 16, 2011 Share Posted September 16, 2011 hello i need help i m trying to use autocad2011,after entering the key,i m getting this error registration error (0015.111) and i can't use autocad..what i have to do for this registration error?? Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 16, 2011 Share Posted September 16, 2011 Rishav: Where did you obtain your copy of AutoCAD 2011? Is this a student version or a full commercial version? You can get assistance with registration errors directly from AutoDesk by calling the number contained within this link...http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10246273&linkID=9240617. Quote Link to comment Share on other sites More sharing options...
Rishav Posted September 16, 2011 Share Posted September 16, 2011 student version from autocad centre Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 16, 2011 Share Posted September 16, 2011 Rishav: I posted a link prior to your reply that might be of use. Note: I cannot honor your friend's request at this time. Sorry. Quote Link to comment Share on other sites More sharing options...
