For me it will always start from 100+00. User input may help others though.
  • Replies 37
  • fixo
    17
  • runner214
    9
  • stevesfr
    8
  • mgraubart
    4
Try attached lisp
~'J'~
Stationing_100.LSP
That works perfect! Thanks for getting back to me so quickly.
Much Appreciated,
Matt
Much Appreciated,
Matt
You're welcome
Glad to help
~'J'~
Fixo:
  • Have worked out the wording position earlier suggested.
  • I insert my block "station" to over ride the lisp created one.
Last item - final total amount - reference attached dwg
also my lisp - referenced as "hal"
Any Ideas?
As usual appreciate your help.
Try attached lisp
~'J'~
Try entering 25 between stations, and the program goes bonkers and gets krazy !! also can you fix 1+0 to read 1+00 ?
thanks for attention to my pieve.
S
Fixo:
Any Ideas?
I will look at your hal.lsp later
Right now I just changed one line of code
Try again
~'j'~
Stationing_50.LSP
fixo:
Thanks for the reply.
The final station correction you supplied ( as per your last send ) totals the ending station but drops the "+" > ie: 388.81 3+88.81
also I changed this line:
(setvar "dimzin" 2) from to (setvar "dimzin" 4)
this is what steve asked earlier, (1+00 (but only strips the ".00")) on every other tic station. please see attached dwg example to better explain.
any suggestions?
S
Steve,
Better yet upload drawing here
and write in there some explanations
~'J'~
Steve,
~'J'~
Attached is result of loading ST100 and requesting 25.00 ft stations.
0+0 should be 0+00
0+25 is OK
1+0 should be 0+50
1+25 should be 0+75
2+0 should be 1+00
2+25 should be 1+25
etc.
?? did I make error in entry or ?
S
st100.dwg
0+0 should be 0+00
0+25 is OK
1+0 should be 0+50
1+25 should be 0+75
2+0 should be 1+00
2+25 should be 1+25
etc.
S
Ah, this make a sense
I know nothing about stationing :)
Ok, I'll rewrite it
~'J'~
0+0 should be 0+00
0+25 is OK
1+0 should be 0+50
1+25 should be 0+75
2+0 should be 1+00
2+25 should be 1+25
etc.
S
Try another one
Let me know if some bugs in there
~'J'~
Stationing_for_Steve.LSP
Well done Mr. fixo!
This version works in all cases mentioned within my original post.
Thank you!
Well done Mr. fixo!
Thank you!
Oh, my God
I'm so happy (I'm tired a bit)
Cheers :)
~'J'~
Try another one
~'J'~
If and when you have the time to perfect it for us surveyors.
One more small item to make it conform to most standard conventions. Rotate the block 180 degrees so it reads correctly from lower to higher stationing (as one would walk along the path)
presently one has to turn their head 180 degrees to read the stationing.
otherwise, great. thanks for the update
S
st-test.dwg
S
Hi Steve,
Try this routine on new drawing, I think that the block
need to be recreated as it is in my code
~'J'~
Stationing_for_Steve_180_degs.LSP
Hi Steve,
~'J'~
Absolutely, positively, PERFECT !!
sincere thanks
S
sincere thanks
S
Glad if that helps for you
Sincerely,
Oleg :D
~'J'~
