I'm in a particular drawing from a customer and the polygon and rectangle command doesn't work. When I do rectangle, only one line from the snap point shows, not the other three. With polygon, you pick a point and usually can see the object when you drag to the next. Here it doesn't show. Circle same thing. All it does is drag a single verticle line with ortho on or off. Revision cloud a series of small verticle lines.
Filedia, pickfirst and pickadd all set to 1. Is there another setting? Layer is on, thawed and not frozen. Also, I just tried to draw a square with the line command with the ortho mode on. It's stuck in a 1 verticle line only mode. Blocks with attributes don't work either. Any help would be appreciated.
Glenn
2009LT
try UCS, World
PLAN, World
try UCS, World
PLAN, World
Man you guys are good. I thought I was gonna be left on my own with this one.
Everything works fine now. Thank you both so much.
Glenn
