Mauser Posted June 7, 2010 Posted June 7, 2010 New to 2010, can't seem to figure out how to draw a leader (I like to use closed arrow head) without getting into a multileader w/text, which is a nice option, but when I just want an arrow, how do I go about it? You can draw a multileader and skip the text, but you are then left with more grips than you need. Thanks Gus Quote
stevsmith Posted June 7, 2010 Posted June 7, 2010 Open up the cui and scroll down the list till you find "Dinension, Leader" and drag it to your toolbar. If you are using the ribbon feature you have to add it to the "ribbon" dropdown menu in the cui. Quote
Mauser Posted June 7, 2010 Author Posted June 7, 2010 Thank you, that's great. You can add individual features to your tool bars, that's pretty slick. Thanks Gus Quote
WtaDude0822 Posted June 8, 2010 Posted June 8, 2010 You can also place a leader by typing QLEADER at the command prompt. You'll notice when you do this that you can either pick your first point or hit "s" for settings. Go into the settings and adjust them to suit your needs. Quote
Mauser Posted June 8, 2010 Author Posted June 8, 2010 Good to know, thanks. I am liking 2010 more and more. Quote
jwoodswahl Posted June 15, 2010 Posted June 15, 2010 A simple LE will also get you a quickleader Quote
