PhilMont Posted June 8, 2010 Posted June 8, 2010 As above^^? how can i create a linetype? and how can i create a linetype with my own text in it? Thanks in advance Phil Quote
numberOCD Posted June 8, 2010 Posted June 8, 2010 In notepad: *LINENAME, LINE DESCRIPTION ----XX------ A,2,["XX",font-style,S=(text height),R=(rotation),X=(lateral offset),Y=(vertical offset)],-.5 You always have an "A" at the start of the second line, then start with a solid dash or a dot, then the text definition in the brackets "[]" When you have the code written you can either copy and paste it into the acad.lin file or save it as it's own .lin file in C:\Documents and Settings\[uSER NAME]\Application Data\Autodesk\[AUTOCAD EDITION]\enu\Support. *NOTE: ALWAYS SAVE IT AS AN .LIN FILE, OTHERWISE IT WILL NOT WORK* I often load my linetypes into the file by opening layer manager, editting the linetype of a layer and browsing for the file and selecting the linetype when prompted. example *GAS_LINE,Gas line ----GAS----GAS----GAS----GAS----GAS----GAS-- A,.5,-.2,["GAS",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-.25 Quote
PhilMont Posted June 8, 2010 Author Posted June 8, 2010 thanks a million. ill work through what you've said and let you know if i have any issues!! no doubt ill screw something up. thanks again. Phil Quote
Tankman Posted June 8, 2010 Posted June 8, 2010 Try ltfly.lsp! I have it load by default each time I open AutoCAD. LTFly Instructions.zip Quote
PhilMont Posted June 9, 2010 Author Posted June 9, 2010 anyway to space the words out more? i have the linetype made (thanks numberOCD) but cannot work out how to "stretch" the linetype? MKLType, isnt a command my cad recognises? and i cant load up that LTfly for some reason? thanks Phil Quote
Tankman Posted June 9, 2010 Posted June 9, 2010 anyway to space the words out more? i have the linetype made (thanks numberOCD) but cannot work out how to "stretch" the linetype? MKLType, isnt a command my cad recognises? and i cant load up that LTfly for some reason? thanks Phil Appload > ltfly.lsp ??? Open the *.zip file first. Quote
