skarfac3 Posted June 8, 2010 Posted June 8, 2010 i have a little problem with autocad. i`m using autocad 2008 and i what to change the LAYOUT from landscape to portrait. thx in advance Quote
rkmcswain Posted June 8, 2010 Posted June 8, 2010 Run the PAGESETUP command. Either modify the current pagesetup or edit/create a new pagesetup and apply. Quote
skarfac3 Posted June 8, 2010 Author Posted June 8, 2010 Run the PAGESETUP command.Either modify the current pagesetup or edit/create a new pagesetup and apply. i want to make the LAYOUT portrait,not to plot the layout that is landspace in portrait.the dwg that i have to do i can show it better in portrait not in landscape it remains some white areas.and the dwg is in the middle. Quote
rkmcswain Posted June 8, 2010 Posted June 8, 2010 i want to make the LAYOUT portrait Which is what I explained how to do. Did you try it? ,not to plot the layout that is landspace in portrait. The layout will plot however it's setup. Set it as portrait and it will plot that way. Quote
skarfac3 Posted June 8, 2010 Author Posted June 8, 2010 i want to make the LAYOUT portrait,not to plot the layout that is landspace in portrait.the dwg that i have to do i can show it better in portrait not in landscape it remains some white areas.and the dwg is in the middle. go to insert -->select Layout--> select Layout Wizzard--> follow the steps and select the orientation of your layout. Voila. Quote
tzframpton Posted June 8, 2010 Posted June 8, 2010 Wizards are a crutch. Get used to PAGESETUP and you'll get familiar with all the options needed for plotting and setup. Quote
skarfac3 Posted June 8, 2010 Author Posted June 8, 2010 Wizards are a crutch. Get used to PAGESETUP and you'll get familiar with all the options needed for plotting and setup. ok i know the page setup but in the drawing i have only 3 areas that i`m interested in.so for me to use the orientation of the layout in portrait is the best solution.i made 3 view ports and below them i can put a legend in another viewport,details...etc .since the dwg is in design as a portrait. thx for the reply rkmcswain and sorry that i didn`t put the correct question and also thx StykFacE for the advice. Quote
Tankman Posted June 8, 2010 Posted June 8, 2010 Open your portrait *.dwt file, minimize. Copy 'n paste from your landscape *.dwg, section by section. I do this on occasion, plan view 'n elevation view, chemical storage tanks. Quote
