How to select more than one line?
When I select a line for, say deleting, when I select the second line the first becomes un-selected. How can I select more than one line at a time please?
AutoCAD will let you to work many ways, to find-out the best way for you. After the first selection, hold down the SHIFT key why selecting the next ones.
You can change this behavior of AutoCAD from the Tools>Options menu or by entering PICKADD in the command line and set it to 1.
Thank you for the prompt reply, I will try your sugestions.
Jim
